Üdvözlet mindenkinek
A címben szereplő kamerának az érintő kijelzőjének a bal fele nem működik.Mi lehet a probléma,találkozott már valaki ezzel a hibával?Az érintő kijelző rossz vagy ez lehet szalagkábel hiba is?Válaszokat előre is köszönöm.
Üdv:Mitu
Hello,
Here is video at the moment that the part can be seen: https://youtu.be/PjEBGFLjgM0?t=410 (from about 6:50 mins). At 10:44 is seen that the part is only in the bottom side of the slot; and nothing more detailed in the whole internet that I was able to check for about a hour.
There is magnetic field sensor - top left on the DSC07181 and on the next photo fitted on its place, so I think it should be some kind of tiny end position switch or don't know what;
Regards,
Milen
Üdvözlök Mindenkit!
Sony DCR-HC19E kamerához keresnék bontott kihajtható LCD kijelzőt.
Durva kezeléstől kitörtek a rögzitő csavarok. Ha valakinél lenne, kérem jelezze. A többit magánban.
Köszönöm
Hello everybody,
Second, when the connexion for standard flexible are cut it is possible to scratch the two parts and connect them with extension wire and welding, but in the case of the CONTROL KEY BLOCK's flexible which is used to connect the CONTROL KEY BLOCK to the mainboard, connexions are not made of copper! (carbon maybe, trying to polish will destroy them!), actually, they are worn out (see picture).
Because these spare parts are no longer available in my country, please I need your advice to fix harness and CONTROL KEY BLOCK's flexible.
