Üdv! Sajnos betörték (kijelző, minden más OK), ha lenne valakinek bontott ilyen készüléke, vevő lennék a plexijére, vagy a komplett előlapra: http://www.kephost.com/view3.php?filename=56lgkrzav1uuxvx7gxz2.jpg
HCD-RG55S (MHC-RG55S)
THX!
Friends Sony STR DH130 goes into protection mode soon after turning on. It works for a second then can hear loud pops from speakers.
I've tried the suggested methods to fix but nothing works. Correct impedance speakers. Speakers wired correct. Good ventilation.
I've tested the output transistors in circuit and I don't see anything unusual. I may pull them to test but will wait for advice here. I also measure
about 57 volts on the emitter resistors. Seems high to me. Anyone?
Hello, I got a problem with my Sony Receiver STR-DE 225.
There´s a sudden interruption of Audio in non defined intervalls - may be once ore 6 times during appr. 5hrs operation.
Interruption does not depend on Volume. Connection cables and speakers I´ve checked.
There´s a loud crack in both speakers, display shows for short time "PROTECTION".
After switching off and on again, everything operates normal until next interruption.
I removed from the inside of the receiver a lot of dust with a vacuum cleaner, but this didn´t help.
Unfortunately Sony has no documents for this device, as it is To "old" (1996), or could give me a hint,
in what cases "PROTECTION" might appear.
Is there anyone to give me a clue? Thanks
Sony MEX-DV1000 autó rádióm van.
A cd-ket beolvassa és szól is.
A probléma az amikor megnyomom az EJECT gombot a cd-t nem akarja kidobni.
Próbáltam visszahajtani a cd mehanizmusát (tehát kivettem a cd-t) és azután belerakni a cd-t. Szépen behúzta a cd-t felismerte, de nem akarta kidobni.
Tehát a cd LOADING műkszik az EJECTING pedig nem.
Előre is köszonöm.
Sikerült medjavitani a rádiót.
A baj zéner diódában volt, a door sw-re. Nem a kapcsolónál hanem a proc. bemeneténél.
Igy hát a proc. úgy ismerte fel hogy az elölap nincsen lenyitva, és akkor nem dobja ki a cd-t.
Most a led diódák is dolgoznak.
Kössz mindenkinek a segitséget.
