Van nekem egy Sony DCR-SR72 videó kamerám, aminek az LCD képernyőjét mozgatva változik a képe hol belilul, hol normál képet ad. Úgy néz ki, hogy a hozzá vezető flat kábele kezd elszakadni. Hol tudnék ilyet beszerezni?
Rittzo
A kamera kihajtható keresője ilyen képet produkál. Látott már valaki így meghibásodni LCD panelt? Köszi!
Hello everybody,
Second, when the connexion for standard flexible are cut it is possible to scratch the two parts and connect them with extension wire and welding, but in the case of the CONTROL KEY BLOCK's flexible which is used to connect the CONTROL KEY BLOCK to the mainboard, connexions are not made of copper! (carbon maybe, trying to polish will destroy them!), actually, they are worn out (see picture).
Because these spare parts are no longer available in my country, please I need your advice to fix harness and CONTROL KEY BLOCK's flexible.
Hello,
Here is video at the moment that the part can be seen: https://youtu.be/PjEBGFLjgM0?t=410 (from about 6:50 mins). At 10:44 is seen that the part is only in the bottom side of the slot; and nothing more detailed in the whole internet that I was able to check for about a hour.
There is magnetic field sensor - top left on the DSC07181 and on the next photo fitted on its place, so I think it should be some kind of tiny end position switch or don't know what;
Regards,
Milen
