Szép napot
Sony hdr-SR12E kézi kamerán reptéri vizsgálat után nem működik az érintős képernyő persze ez lehet véletlen is mivel repülés előtt ha mozgatva volt a kijelző néha villogott a kép.
Most a kapcs rajz szerint a Q5901 XP411F-txe Q5902 XP421-txe lehetne talán a hibás de nem biztos
János
Hello,
Here is video at the moment that the part can be seen: https://youtu.be/PjEBGFLjgM0?t=410 (from about 6:50 mins). At 10:44 is seen that the part is only in the bottom side of the slot; and nothing more detailed in the whole internet that I was able to check for about a hour.
There is magnetic field sensor - top left on the DSC07181 and on the next photo fitted on its place, so I think it should be some kind of tiny end position switch or don't know what;
Regards,
Milen
Üdv! Mit lehet ilyenkor tenni? Mitől lehet? A menüben sem engedi formatálni... :( 100GB Toshiba HDD van benne.
Hello everybody,
Second, when the connexion for standard flexible are cut it is possible to scratch the two parts and connect them with extension wire and welding, but in the case of the CONTROL KEY BLOCK's flexible which is used to connect the CONTROL KEY BLOCK to the mainboard, connexions are not made of copper! (carbon maybe, trying to polish will destroy them!), actually, they are worn out (see picture).
Because these spare parts are no longer available in my country, please I need your advice to fix harness and CONTROL KEY BLOCK's flexible.
