SONY DVD CODE C-81 2
VIDEO-DVD - SERVICE MANUAL
25.0 KB
SONY DVD CODE C-81 2 service manual (1st page)
Preview of SONY DVD CODE C-81 2 [1st page]
    SONY DVD CODE C-81 C81 81
Sony SLV E177
Sziasztok! A fent nevezett videóval lenne gondom. Mégpedig az, hogy időszakosan nem veszi be a kazettát ill. nem is adja ki(ha véletlen bevette). A mechanika mozgató motorral sorosan van egy 33 ohm os ellenállat az tűzforró de annyira hogy körülötte már minden feketedik. A mechanikát tisztítottam, elvileg nem is szorul, viszont ha megmozdítom a motortengelyt akkor működik. Mi lehet a gondja? Segítségeteket köszönöm. Krisz
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
sony slv 777 vp nem érzékeli a kazettát
sziasztok! adott egy sony slv 777vp hifi stereo video hibás táppal. szétszedés után látszik hogy valaki már buherálta. hiányzik a táp ic tipusa: ma2831,és egy kondi felrobbant benne ,csicsog minden. tehát kérdésem hol és mennyiért lehet ilyen táp ic-t beszerezni? vagy esetleg komplett táp ha van valakinek akkor megvenném. üdv:atis
SONY VCR
SZiasztok Van egy Sony SLV363EE videóm.A capstan motorja 2-3mp-ként megáll egy pillanatra.A hozzászólásokat előre is köszönöm.
