SONY DVP-NC600
VIDEO-DVD - SERVICE MANUAL
20.6 MB
SONY DVP-NC600 service manual (1st page)
Preview of SONY DVP-NC600 [1st page]
SONY DVP-NC600 service manual (2nd page)
Preview of SONY DVP-NC600 [2nd page]
    SONY DVPNC-600 DVPNC600 DVPNC 600 DVP NC600 DVP-NC600
RMT-V198B SONY távirányitó
Üdv. mindenkinek! Ha kell valakinek ez a távirányitó- üzemképes- szivesen adom. Tisztelettel, welding alt
SONY SLV-E 170,150,580 betöltő motor tengelyén lévő műanyag elrepedős alkatrész!
SONY SLV-E 170,150,580 betöltő motor tengelyén lévő műanyag elrepedős alkatrészt honnan lehet beszerezni?
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
SONY UVW-1800P video nem kapcsolható be. (megoldva)
Próbálok lelket verni eme szerkezetbe, de nem járok sikerrel. Bekapcsolást követően mindössze a stop gomb világít és ennyi. Tápegységről lejönnek a megfelelő feszültségek és a segédtápok is felállnak. Persze ez utóbbit a modulos elrendezés miatt nehéz ellenőrizni. Szóval még a kijelzés sem látható. Tudom kevés az esély, de gondoltam rákérdezek, volt-e ezeknek valami "tipikus" hibájuk amivel találkozott már valaki.
Köszönettel: Kiss Z.
Update: Kijelző hiba miatt nem lehetett látni, hogy be van-e kapcsolva. Mint kiderült, "köztes" állapotban ragadt meg a mechanika (rugótörés) ami a driver IC halálát is okozta. Ezeket elhárítva már tökéletesen játszott le a készülék. Kijelző panelt átvizsgálva, 5db 47uf kondi kifolyva, (nanós nagyságrend) ami szétmarta a fóliákat. Hat helyen a furatgalván is áldozatul esett, amit a lyukakon átdugott és forrasztott huzaldarabbal orvosoltam. Megjegyzem, kora ellenére tökéletes képet játszik le a készülék. Szerencsére, hiszen a néprajzi múzeum tulajdona és a kazetták "archiválásához" akarják használni.
