SONY DVP-NS325 DVP-NS330 DVP-NS333 DVP-NS430 DVP-NS433 DVP-NS530 DVP-NS725 DVP-NS730
VIDEO-DVD - SERVICE MANUAL
23.8 MB
SONY DVP-NS325 DVP-NS330 DVP-NS333 DVP-NS430 DVP-NS433 DVP-NS530 DVP-NS725 DVP-NS730 service manual (1st page)
Preview of SONY DVP-NS325 DVP-NS330 DVP-NS333 DVP-NS430 DVP-NS433 DVP-NS530 DVP-NS725 DVP-NS730 [1st page]
SONY DVP-NS325 DVP-NS330 DVP-NS333 DVP-NS430 DVP-NS433 DVP-NS530 DVP-NS725 DVP-NS730 service manual (2nd page)
Preview of SONY DVP-NS325 DVP-NS330 DVP-NS333 DVP-NS430 DVP-NS433 DVP-NS530 DVP-NS725 DVP-NS730 [2nd page]
    SONY DVPNS-325 DVPNS325 DVPNS330 DVPNS333 DVPNS430 DVPNS433 DVPNS530 DVPNS725 DVPNS730 DVPNS 325 330 333 430 433 530 725 730 DVP NS325 NS330 NS333 NS430 NS433 NS530 NS725 NS730 DVP-NS325 DVP-NS330 DVP-NS333 DVP-NS430 DVP-NS433 DVP-NS530 DVP-NS725 DVP-NS730
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Sony SLV-X9N videó eject utasításra kiadja a kazettát, de rögtön vissza is tölti.
Sony SLV-X9N videó eject utasításra kiadja a kazettát, de azonnal vissza is tölti. A mode-switch kitakarítva, a panelon lévő mikrokapcsoló megjavítva. A  sasszin lévő fogaslécen egy kis műanyag lapka le volt törve, azt visszaépítettem, remélem jól. Persze, ha elég gyors vagyok, ki tudom venni a kazettát, de akkor is visszaindul a kazetta fészek, de természetesen elakad a reteszelő lemez (remélem, ez a neve) miatt. Tudna valaki tanácsot adni, hogy hogyan tovább?
Köszönettel:
sony slv-x711sg videóba ékszij
Tisztelt szakik.
A címben említett készülékbe milyen méretű ékszijjak kellenek?
A gép könyv itt a tanyán van, de a méreteket nem találtam. 36.o 859, 861, 876 számú.
Viszont nem találtam alkatrész listát.
Lehetne mérni a meglévőket, de ki vannak lágyulva, nyúlva. Nem lenne pontos.
Köszönettel D Attila
Sony SLV E177
Sziasztok! A fent nevezett videóval lenne gondom. Mégpedig az, hogy időszakosan nem veszi be a kazettát ill. nem is adja ki(ha véletlen bevette). A mechanika mozgató motorral sorosan van egy 33 ohm os ellenállat az tűzforró de annyira hogy körülötte már minden feketedik. A mechanikát tisztítottam, elvileg nem is szorul, viszont ha megmozdítom a motortengelyt akkor működik. Mi lehet a gondja? Segítségeteket köszönöm. Krisz
