SONY HBD-HZ970W IZ1000W VER-1.0 SM
VIDEO-DVD - SERVICE MANUAL
9.8 MB
SONY HBD-HZ970W IZ1000W VER-1.0 SM service manual (1st page)
Preview of SONY HBD-HZ970W IZ1000W VER-1.0 SM [1st page]
SONY HBD-HZ970W IZ1000W VER-1.0 SM service manual (2nd page)
Preview of SONY HBD-HZ970W IZ1000W VER-1.0 SM [2nd page]
    SONY HBDHZ-970W IZ-1000W HBDHZ970W IZ1000W HBDHZ 970 IZ 1000 HBD HZ970W 1.0 HBD-HZ970W
SONY EV-S550E Video 8 nem játsza le a kazettát ,illetve zajos a kép...
Sziasztok A címben szereplő video8 hoz keresnék rajzot de sajna itt a tanyán nincsen hozzá próbáltam keresni hozzá rajzot de nem találtam . Hibe jelenség csikozva játszik le és így is vesz fel valoszinü fejhibás de kéne hozzá egy pontos tipus hogy milyen fej való bele ezért keresek hozzá gyári rajzot hogy megtudjam nézni a fej tipusát . Ha valaki tud segitsen . Már régóta megy a topik, és nem a rajz a lényeg benne. Légy szíves igazítsd ki a címet!
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
sony SLV-E870
Üdv mindenkinek: javításra hoztak egy a címbben szereplő videót .Hibajelenség mechanika nem áll alaphelyzetbe kazettát ezáltal nem is viszi be.Kijelző a következő hibakódok jelennek meg felváltva 1L60,1L61, 1L63 :Eddig elvégezve: Szétszedtem a mechanikát program tárcsát tisztítottam minden jelölés pozícióba állítva mégis a hiba változatlan."Alaphelyzetben" a kazettafészket próbálja mozgatni de nem tudja: MIÉRT??
Sony SLV-E570 video nem indul
Tudna valaki segíteni? Egy Sony SLV-E570 video nem veszi be a kazettát. Betolva azt írja ki, hogy  1 60 31. A következő behelyezési kísérletnél 2 60 31, majd ezután 3 60 31. a SM-ban nem találtam rá utalást.
Köszönettel:
