Bekottem az automba egy sony cd lejatszot, (egy opel astraba) s az auto kijelzojerol eltunt a datum, nem mutassa...
Vki tudna nekem segiteni, hogy mit kell atkotni, hogy ismet mutassa a datumot?
Elore is koszonom
A tárgybeli hifi áramalá helyezése után ry902 relét meghuzza és elejti , igy produkálja nekem ezt a villogó bekapcsoló gomb hibát.
Kérdésem az lenne hogy mi tiltja le mit ellenöriz igy induláskor (végfokok jónak mértem ki őket)
elöre is köszönöm segitségeteket
misi
Friends Sony STR DH130 goes into protection mode soon after turning on. It works for a second then can hear loud pops from speakers.
I've tried the suggested methods to fix but nothing works. Correct impedance speakers. Speakers wired correct. Good ventilation.
I've tested the output transistors in circuit and I don't see anything unusual. I may pull them to test but will wait for advice here. I also measure
about 57 volts on the emitter resistors. Seems high to me. Anyone?
Hello, I got a problem with my Sony Receiver STR-DE 225.
There´s a sudden interruption of Audio in non defined intervalls - may be once ore 6 times during appr. 5hrs operation.
Interruption does not depend on Volume. Connection cables and speakers I´ve checked.
There´s a loud crack in both speakers, display shows for short time "PROTECTION".
After switching off and on again, everything operates normal until next interruption.
I removed from the inside of the receiver a lot of dust with a vacuum cleaner, but this didn´t help.
Unfortunately Sony has no documents for this device, as it is To "old" (1996), or could give me a hint,
in what cases "PROTECTION" might appear.
Is there anyone to give me a clue? Thanks
