SONY HCD SB300
VIDEO-DVD - SERVICE MANUAL
8.9 MB
SONY HCD SB300 service manual (1st page)
Preview of SONY HCD SB300 [1st page]
SONY HCD SB300 service manual (2nd page)
Preview of SONY HCD SB300 [2nd page]
    SONY HCD SB-300 SB300 SB 300
Sony SLV715 kép van hang nincsen..
Sziasztok Van egy Video magnóm a tipusa SONY SLV-715 a következő hibát produkálja a kazettát betéve elindul a lejátszás kép van hang nincsen a kijelzö nem számlál a kép kb 2mp enként elmegy majd újra van kép és a traking led villog folyamtosan ,ha valakinek lenne ötlete hogy mi lehet a baja ,fejet megtisztogattam de semmi eredmény más ötletem most nincsen táp rendben van elkók jók a feszültségek meg vannak ...
Sony EV-S1000E: service manual is missing the Power Supply schema
Hello everybody,
I'm trying to fix an old Sony vcr with some PS issues and unfortunately from the service manual (the one with electric schema) I've downloaded from this very good service the PS circuit is missing.
Anyone with the original manual may help me?
Thank you!
Franco
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Sony SLV E177
Sziasztok! A fent nevezett videóval lenne gondom. Mégpedig az, hogy időszakosan nem veszi be a kazettát ill. nem is adja ki(ha véletlen bevette). A mechanika mozgató motorral sorosan van egy 33 ohm os ellenállat az tűzforró de annyira hogy körülötte már minden feketedik. A mechanikát tisztítottam, elvileg nem is szorul, viszont ha megmozdítom a motortengelyt akkor működik. Mi lehet a gondja? Segítségeteket köszönöm. Krisz
