T. Fórumozók !
A fenti LCD-hez kérnék javítási tanácsot! Hiba jelenség: a készülék ciklikusan be-ki kapcsolgat.Az alatt a 8sec alatt amíg üzemel hang van kép nincs csak tejfehér kijelző .A tápot megvizsgáltam a feszültségek rendben .A segítségeteket előre is köszönöm!
T. kollegák4
Sony KV 32 CS70E TV /100hz/ javításához kérem segítségeteket
H pozició jobbra erőteljesen elcsúszva.
A menübe bemenve, alig történik valami.
Tippeket kérek.
Üdv.Niagara21
Hello
I have on my table this sony kdl32ex600 with backlight issue. It's a common failure of this psu but i do not find any part faulted on this board.
The schematic it is almost the same, with minor differences with GE3B found at page 56 on this service manual:
https://elektrotanya.com/sony_kdl-32ex600_kdl-40ex600_kdl46ex600_chassis_az1-k.pdf/download.html
Uploaded only the page 56 from this sm to easing the search.
The red led it's flashing 2 times, meaning psu faulty. Indeed the led backlight does not light.
With the PSU outside of the tv, just with one resistance of 180ohm between standby ( pin 1 3,3V on connector CN6150 ) i get this values
on in:
starting with pin 1
1 +3,3V ST-BY
2 +3,3V AC_OFF_DET
3 +3,3V POWER_ON (with resistance 180ohm between pin1 and pin 3)
4 +12,56V AUDIO_12V
5 0V AUDIO_12V_GND
6 0V REG_12V_GND
7 0V REG_12V_GND
8 +12,6V REG_12V
9 +12,6V REG_12V
10 +0,1V BL_ERR
11 +3,3V BL_ON
12 0V DIMMER
13 0V DIMMER_DC
14 0V T-CON_Vcc_12V
15 0V T-CON_ON
All measure done at secondary ground point C6800 GND as reference.
Meanwhile, the led connected to CN6800 will remain with no light at all. The CN6800 will deliver positive 91V.
The negative branch will deliver at CN6801 ( both pin1 & 2 ) just -1V.
In the training manual found always in here at
https://elektrotanya.com/sony_kdl-32ex600_40ex600_46ex600_chassis_az1k_training%20manual.pdf/download.html
at page 56 will say "SHORT" at pin 12 DIMMER for testing the PSU, always with pin 3 POWER_ON connected to 3,3V ST-BY - pin1.
If i'll put a 180ohm resistance between GND and pin 12 DIMMER, then the tension on CN6800 will rise to +179V and the negative from the CN6801 will rise to -5V, the backlight led will light very very weak.
All tension from CN6805 will remain the same, except the BL_ERR will rise from +0,1V to +1,1V.
With only power_on pin 3 shorted by 180ohm resistance to the pin 1, i get this weak oscillation at emiter of Q6816 + Q6817
[URL=https://picturepush.com/public/16067400][IMG]https://www1.picturepush.com/photo/a/16067400/640/diverse/Q6816Q6817.jpg[/IMG][/URL]
With pin 12 DIMMER shorted ( always by a 180ohm resistance ) at GND, the oscillation will change from 250khz 1,6vpp to almost 70khz at 0,81Vpp. as below:
[URL=https://picturepush.com/public/16067401][IMG]https://www1.picturepush.com/photo/a/16067401/640/diverse/20181117-175255.jpg[/IMG][/URL]
Already checked the capacitors C6828 / C6830 together with D6805 / D6806.
Also checked the L6800 ( trafo ) and i've get 5,5mH instead of 5mH, i think it's ok.
All fuse checked, ok.
Q6814 and Q6801 tested under mosfet tester, ok.
[url=https://picturepush.com/public/16067402][img=https://www1.picturepush.com/photo/a/16067402/220/16067402.jpg][/url]
IC6800 & IC6801 gave +9V and respectively +2,49V
Already checked various components all over the board, i am out of ideas.
Any idea or help would be apreciated.
Tegnap hozzám került egy hiányos belű Sony KDL-26U2000 típusú LCD TV. Mivel eléggé jutányos áron szereztem, használni is szeretném. A belsejéről csatolok egy képet. Németországból származik a készülék. Ott berhelték ki belőle az AV részleget és az invertert. Megmaradt a kijelző, a táp és az alaplap. A tápból hiányzik a biztosíték és egy szervizdoksi alapján beazonosított MCZ3001DB IC amit már megrendeltem és pótolok majd. A fő kérdésem az lenne, hogy a tuner és AV rész nélkül elindul-e a tv, mert az alaplapon van 1 HDMI és egy VGA csatlakozó amivel monitorként használhatnám a készüléket.
Arra gondoltam, hogy legvégső esetben egy másik LVDS vezérlőről kapná a panel a jelet csak nem tudom ez mennyire lehetséges (monitoroknál eddig működött a dolog de itt lényegesen más a felbontás (1366*768))
Az ötleteket előre is köszönöm!
