Hello to everyone, i have a problem with this Sony LCD
Sony KDL-37W5500
Chassis EX2L
MAINBOARD: 1-878-942-22
PANEL: T370HW02
Audio Amp: TAS5602
Sound System: CXA3785R-T6
main CPU: EMMA3 (under heat sink should be MB91F313APMC-GE1)
Power Supply: G4, 3H267W, PSC10270F
When i try to turn it on it clicks relay, blinks 1x Green Led, then it shuts down and blinks 8x Red Led.
Looking at service manual it should be an Audio Error. When i try to enter Self Diagnostic Menu it just wont light up the screen. I do the sequence "I+" "5" "V-" "Power" and it powers up regularly-fault 1xgreen 8x red, black screen.
From power supply i get all the voltages, except that 15V is 17.4V constant, but at the moment of powering it overshoots at 24V briefly.
Also i don't get D3.3V voltage. I have 12V on regulator BD9540EFV, but enable pins 3 and 12 are held too low on 1.6V, and it need at least 2.2V to enable output, so i dont have 3.3V, only 0,7V.
DVDD 3.3v is logic supply, so i dont get how CPU gets logic levels from ICs for error when there is no Logic Supply...
When i measure the power for audio amplifier TAS5602DCAR it should be 13V i suppose, but it gets 17.4V, from the CON1300 pins 4 and 5. It is ok for that IC, it works on voltages until 30V, but I worry if that does not affect some other processes.
Fault signal from audio amp TAS5602DCAR is on PIN19 and it is 3.3V that is HIGH and it suggests Normal Operation.
On sound system IC CXA3785R-T6 pin44 the VFAULT signal is LOW 0.7V, that is too normal operation.
But on audio amp pin18 TAS5602DCAR RESET is held in LOW and it does not go to HIGH to get out of the reset mode. That pin is controlled by main CPU signal X_SP_Mute.
On sound system IC CXA3785R-T6 pin43 X_Protect output is LOW 0.4V that means ERROR.
In datasheet it says X_PROTECTOUT outputs “L” when input voltage (SPxP/N) become under 3.0V.
That is on pins 61-62 and 63-64, and if I understand right it needs to have 3+ V DC to output High Normal signal?
Isnt that a bit too high to have on speakers? I measure 0V DC there, and 25mV AC.
Also i can not find anywhere schematics for PSU board PSC10270F(3H267W), i need it because i think that this 15V should be around 15V not 17,4V. I did find zener diode that i think acts as a stabilizator and it measures ok, but i would replace it if i knew the markings that can not be read.
All google stuff is from my posts so google wont help :)
What do you think can be the main problem and solution for this ?
I exclude replacing whole board
I have and Audio Amp IC coming soon to replace, but i think that wont help.
p.s.
If anyone wants i can upload all pdfs that i have, ex2l SM, datasheets for audio ICs, datasheet for 3,3V regulator ect...
Az antenna bemenetről " nincs jel". Az internetet eléri, analóg bemenet működik.
A tulajdonos elmondása szerint újra akarta hangolni az egyik csatornát és azóta ez van.
TV szerelésben, de még csak a használatban sincs tapasztalatom, lehet, hogy valami el van állítva, de én nem találtam meg.
Milyen alap dolgokat nézzek meg?
Köszönettel
Szeretnék segítséget kérni a következőben:
Egy Samsung LE40S81B TV és egy Sony BDP-S7200 Blu-ray lejátszó jó ideig működtek együtt gond nélkül HDMI-n.
Egyszer csak a beltéri egység képe a HDMI1 bemeneten zajos lett,és ezek után a HDMI2 bemeneten eltűnt a lejátszó képe.
Eddig semmi érdekes...
A Sony playert egy másik TV-hez csatlakoztatva hibátlanul működik.
A TV-szétszedtem,nagyító alatt átnéztem a HDMI csatlakozók forrasztásait,kitakarítottam Kontakt WL-el.
Azóta a zaj eltűnt és mindkét HDMI bemenet működik a TV-n.
Csak együtt nem.
Próbáltam kábeleket cserélni,ugyanaz.
Csak a kettőt összecsatlakoztatni,minden más perifériát kizárni,semmi.
Átállítottam a Sony kimenő felbontását 1080i-re,amivel a beltéri is üzemel,semmi.
A Sony bekapcsolásakor fél másodpercig bevillan a fő képernyő,aztán sötét.
Előre is köszönök minden ötletet.
Köszönettel
A karcsú sertés
mivel a készülékről letépték a típusszámot, a kijelző típusát írtam a címbe.
Az a baj vele, hogy a kép (OSD is) függőleges irányban szellemképes. A Menü tábla is halványabban és bizonytalanul többször jelenik meg. Én T-con hibára gondolok, megköszönném a tapasztalatok alapján a cáfolatot vagy megerősítést.
Köszi
Tamás
