SONY PBD-D50 DVD-ROM DRIVE
VIDEO-DVD - SERVICE MANUAL
14.4 MB
SONY PBD-D50 DVD-ROM DRIVE service manual (1st page)
Preview of SONY PBD-D50 DVD-ROM DRIVE [1st page]
SONY PBD-D50 DVD-ROM DRIVE service manual (2nd page)
Preview of SONY PBD-D50 DVD-ROM DRIVE [2nd page]
    SONY PBDD-50 DRIVE PBDD50 DVDROM PBDD 50 PBD D50 DVD ROM PBD-D50 DVD-ROM
SONY EV-S550E Video 8 nem játsza le a kazettát ,illetve zajos a kép...
Sziasztok A címben szereplő video8 hoz keresnék rajzot de sajna itt a tanyán nincsen hozzá próbáltam keresni hozzá rajzot de nem találtam . Hibe jelenség csikozva játszik le és így is vesz fel valoszinü fejhibás de kéne hozzá egy pontos tipus hogy milyen fej való bele ezért keresek hozzá gyári rajzot hogy megtudjam nézni a fej tipusát . Ha valaki tud segitsen . Már régóta megy a topik, és nem a rajz a lényeg benne. Légy szíves igazítsd ki a címet!
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
SONY SLV-E 170,150,580 betöltő motor tengelyén lévő műanyag elrepedős alkatrész!
SONY SLV-E 170,150,580 betöltő motor tengelyén lévő műanyag elrepedős alkatrészt honnan lehet beszerezni?
sony SLV-E870
Üdv mindenkinek: javításra hoztak egy a címbben szereplő videót .Hibajelenség mechanika nem áll alaphelyzetbe kazettát ezáltal nem is viszi be.Kijelző a következő hibakódok jelennek meg felváltva 1L60,1L61, 1L63 :Eddig elvégezve: Szétszedtem a mechanikát program tárcsát tisztítottam minden jelölés pozícióba állítva mégis a hiba változatlan."Alaphelyzetben" a kazettafészket próbálja mozgatni de nem tudja: MIÉRT??
