SONY SLV-777HF 778HF 788HF RMT-V231B 232B
VIDEO-DVD - SERVICE MANUAL
8.7 MB
SONY SLV-777HF 778HF 788HF RMT-V231B 232B service manual (1st page)
Preview of SONY SLV-777HF 778HF 788HF RMT-V231B 232B [1st page]
SONY SLV-777HF 778HF 788HF RMT-V231B 232B service manual (2nd page)
Preview of SONY SLV-777HF 778HF 788HF RMT-V231B 232B [2nd page]
    SONY SLV-777HF RMTV-231B SLV777HF 778HF 788HF RMTV231B 232B SLV 777 HF 778 788 RMTV 231 232 777HF RMT V231B RMT-V231B
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
sony slv-x711sg videóba ékszij
Tisztelt szakik.
A címben említett készülékbe milyen méretű ékszijjak kellenek?
A gép könyv itt a tanyán van, de a méreteket nem találtam. 36.o 859, 861, 876 számú.
Viszont nem találtam alkatrész listát.
Lehetne mérni a meglévőket, de ki vannak lágyulva, nyúlva. Nem lenne pontos.
Köszönettel D Attila
SONY SLV-SE727E - tracking hiba?
Sziasztok! A fenti videó az LP-t szépen felveszi, le is adja, de SP-ben tracking jellegű hibát produkál. Saját és más felvétellel is. Samuknál szokott ilyen lenni, amikor elmegy az opciója. Ami zavar, hogy SP-ben rossz, LP-ben nem. Használta az ügyfél rendesen. Kopott, vagy opcióhibás ez is? Ha valakinek van ötlete, kérem, ossza meg velem! Szép napot! Laci
Sony slv 282 ee távvezérlő
Sziasztok! Hozzájutottam EGY SONY SLV-282EE tipusu vídeóhoz de nincs távvezérlője. A tanítható távval csak az alapvető funkciók futnak. Hol lehet beszerezni az eredeti tipust vagy a "kompatibilis" változatot? Űdv.József
