Hello!
A fent említett típusú video bekapcsolás után pár percel kikapcsol, készenlét sincs ha valaki tud segíteni megköszönöm.
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Próbálok lelket verni eme szerkezetbe, de nem járok sikerrel. Bekapcsolást követően mindössze a stop gomb világít és ennyi. Tápegységről lejönnek a megfelelő feszültségek és a segédtápok is felállnak. Persze ez utóbbit a modulos elrendezés miatt nehéz ellenőrizni. Szóval még a kijelzés sem látható. Tudom kevés az esély, de gondoltam rákérdezek, volt-e ezeknek valami "tipikus" hibájuk amivel találkozott már valaki.
Köszönettel: Kiss Z.
Update: Kijelző hiba miatt nem lehetett látni, hogy be van-e kapcsolva. Mint kiderült, "köztes" állapotban ragadt meg a mechanika (rugótörés) ami a driver IC halálát is okozta. Ezeket elhárítva már tökéletesen játszott le a készülék. Kijelző panelt átvizsgálva, 5db 47uf kondi kifolyva, (nanós nagyságrend) ami szétmarta a fóliákat. Hat helyen a furatgalván is áldozatul esett, amit a lyukakon átdugott és forrasztott huzaldarabbal orvosoltam. Megjegyzem, kora ellenére tökéletes képet játszik le a készülék. Szerencsére, hiszen a néprajzi múzeum tulajdona és a kazetták "archiválásához" akarják használni.
Van nálam egy Sony videó. Nem indul a tápja, a szokásos katt-katt-katt másodpercenként. Kicseréltem benne az összes elkót, az optót, a feszültség referenciát, kínomban már a tápIC-t is, mindhiába.
A rajz:
http://kepfeltoltes.hu/view/091112/sony_www.kepfeltoltes.hu_.gif
A pirossal jelölt helyeken leválasztottam az áramkört, hogy ne zavarjon be, a zöld alkatrészek cserélve. Műterhelés van a kimeneten. A bemeneten megvan az egyenirányított hálózati feszültség, a tápIC megkapja a névleges tápot (13V), a szekunder oldalon a kattogással szinkronban megjelenik a feszültség is arra a rövid időre, amíg egy impulzus lefut.
Ellenállásokat végigmértem, mindegyik névleges. A bemeneti áramkorlátozó értéke 0.33 ohm, ezt nem tudom ellenőrizni, a műszerem nem ennyire pontosm, de az értéke kisebb mint 1 ohm, úgyhogy jónak feltételezem.
Tudtok segíteni? Mit nézzek még ezen a szutykon?
DM
