SONY SLV-D990P SLV-D995P-E-R DVD-VCR SM
VIDEO-DVD - SERVICE MANUAL
19.1 MB
SONY SLV-D990P SLV-D995P-E-R DVD-VCR SM service manual (1st page)
Preview of SONY SLV-D990P SLV-D995P-E-R DVD-VCR SM [1st page]
SONY SLV-D990P SLV-D995P-E-R DVD-VCR SM service manual (2nd page)
Preview of SONY SLV-D990P SLV-D995P-E-R DVD-VCR SM [2nd page]
    SONY SLVD-990P DVDVCR SLVD990P SLVD995PER SLVD 990 995 PER SLV D990P D995P DVD VCR SLV-D990P DVD-VCR
Sony SLV-X9N videó eject utasításra kiadja a kazettát, de rögtön vissza is tölti.
Sony SLV-X9N videó eject utasításra kiadja a kazettát, de azonnal vissza is tölti. A mode-switch kitakarítva, a panelon lévő mikrokapcsoló megjavítva. A  sasszin lévő fogaslécen egy kis műanyag lapka le volt törve, azt visszaépítettem, remélem jól. Persze, ha elég gyors vagyok, ki tudom venni a kazettát, de akkor is visszaindul a kazetta fészek, de természetesen elakad a reteszelő lemez (remélem, ez a neve) miatt. Tudna valaki tanácsot adni, hogy hogyan tovább?
Köszönettel:
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
SONY UVW-1800P video nem kapcsolható be. (megoldva)
Próbálok lelket verni eme szerkezetbe, de nem járok sikerrel. Bekapcsolást követően mindössze a stop gomb világít és ennyi. Tápegységről lejönnek a megfelelő feszültségek és a segédtápok is felállnak. Persze ez utóbbit a modulos elrendezés miatt nehéz ellenőrizni. Szóval még a kijelzés sem látható. Tudom kevés az esély, de gondoltam rákérdezek, volt-e ezeknek valami "tipikus" hibájuk amivel találkozott már valaki.
Köszönettel: Kiss Z.
Update: Kijelző hiba miatt nem lehetett látni, hogy be van-e kapcsolva. Mint kiderült, "köztes" állapotban ragadt meg a mechanika (rugótörés) ami a driver IC halálát is okozta. Ezeket elhárítva már tökéletesen játszott le a készülék. Kijelző panelt átvizsgálva, 5db 47uf kondi kifolyva, (nanós nagyságrend) ami szétmarta a fóliákat. Hat helyen a furatgalván is áldozatul esett, amit a lyukakon átdugott és forrasztott huzaldarabbal orvosoltam. Megjegyzem, kora ellenére tökéletes képet játszik le a készülék. Szerencsére, hiszen a néprajzi múzeum tulajdona és a kazetták "archiválásához" akarják használni.
Sony slv 282 ee távvezérlő
Sziasztok! Hozzájutottam EGY SONY SLV-282EE tipusu vídeóhoz de nincs távvezérlője. A tanítható távval csak az alapvető funkciók futnak. Hol lehet beszerezni az eredeti tipust vagy a "kompatibilis" változatot? Űdv.József
