SONY SLV-ED10,40,60,70
VIDEO-DVD - SERVICE MANUAL
23.3 MB
SONY SLV-ED10,40,60,70 service manual (1st page)
Preview of SONY SLV-ED10,40,60,70 [1st page]
SONY SLV-ED10,40,60,70 service manual (2nd page)
Preview of SONY SLV-ED10,40,60,70 [2nd page]
    SONY SLVED-10 SLVED10 40 60 70 SLVED 10 SLV ED10 SLV-ED10
Sony EV-S1000E: service manual is missing the Power Supply schema
Hello everybody,
I'm trying to fix an old Sony vcr with some PS issues and unfortunately from the service manual (the one with electric schema) I've downloaded from this very good service the PS circuit is missing.
Anyone with the original manual may help me?
Thank you!
Franco
SONY VCR
SZiasztok Van egy Sony SLV363EE videóm.A capstan motorja 2-3mp-ként megáll egy pillanatra.A hozzászólásokat előre is köszönöm.
Sony slv-x57 javíthatatlan?
Sziasztok! Apum kitett magáért. Van egy címben szereplő video, azt mondták neki nem érdemes megjavítani, erre miszlikbe szedte :( Miért nem hallgat soha rám... Ki ismeri ezt a gépet? Netán tényleg egy gagyi gép és nem volt kár érte? Üdv: Pityesz
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
