SONY SLV-EX50 EX80S EX90S
VIDEO-DVD - SERVICE MANUAL
4.7 MB
SONY SLV-EX50 EX80S EX90S service manual (1st page)
Preview of SONY SLV-EX50 EX80S EX90S [1st page]
SONY SLV-EX50 EX80S EX90S service manual (2nd page)
Preview of SONY SLV-EX50 EX80S EX90S [2nd page]
    SONY SLVEX-50 EX-90S SLVEX50 EX80S EX90S SLVEX 50 EX 80 90 SLV EX50 SLV-EX50
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Sony slv 282 ee távvezérlő
Sziasztok! Hozzájutottam EGY SONY SLV-282EE tipusu vídeóhoz de nincs távvezérlője. A tanítható távval csak az alapvető funkciók futnak. Hol lehet beszerezni az eredeti tipust vagy a "kompatibilis" változatot? Űdv.József
sony slv-615
Üdv! A készülék saját, szeretem mert igényes tipus és a régi felvételeket még mindig tökéletesen játsza le. Eddig. Most stereoban zúg a hangja, a mono filmekkel kifogástalan. A tanyán nincs róla dokument, egy SM jól jönne.
SONY SLV-E 170,150,580 betöltő motor tengelyén lévő műanyag elrepedős alkatrész!
SONY SLV-E 170,150,580 betöltő motor tengelyén lévő műanyag elrepedős alkatrészt honnan lehet beszerezni?
