Want to share:
Have downloaded the schematics from this forum to help repair the amplifier of a friend.
Turned out that Sony decided to route the earth through the chassis, even the earth between the various supplies.
When one takes the main board out of the chassis and switches the amp on, there are up to 20 volts difference between the eart (and hence reference) of the pre-amps and the main amps.
Luckily the amp goes into protection but from a design point of view it is not nice to rely on screws and aluminum face plates to conduct up to 0.2 amps of current from one supply to another.
What I did is solder wires to every eart point and connected them on the main board to make it stand alone and not rely on conducting current through the chassis anymore.
Bad design, simple repair but took some digging in the schematics to find out what exactly was going on!
Hali!
Kicseréltem a mikrokapcsolókat ,de semmi vátozás!
Bekapcs, tuner 2x villan majd kiirja eject!
Táp mindenhol jó!
Még mindig nem tudom mi lehet a baja ?
Talán procihiba?
SEGÍTSETEK!!!!
Üdv Korz
Van egy Sony CDX-R3300-as autós CD, ami a bekapcsolás után csak a demo-funkciót végzi, semmit nem lehet vele kezdeni. A SM-okban semmit nem találtam erről. Tudna valaki segíteni?
Köszönettel
Nincs valakinek a fenti készülékhez doksija?
Valaki kissé átrendezte. Főleg a mechanikáról kéne rajz ha van de a többi rész sem
ártana ha volna.
Előre is kösz.
Üdv: Lajos
