USSR OREANDA 302.
587.9 KB
Looking for similar ussr manual?
    USSR OREANDA 302. 302
AKAI UC-U2 erősítő keverő-előerősítő panel hiányos
Köszöntöm a Kedves Tanyalakókat ! Segítséget szeretnék kérni... az AKAI UC-U2 erősítő keverő/előerősítő panelja hiányos (sérült) a mellékelt képek szerint. Szeretném a panelt kiegészíteni és az ismeretlen alkatrészekkel beültetni. Javításával kedves barátomnak szereznék örömet.
NAD 3140 amplifier - power transistors getting hot
This one had been sitting in a barn for years. Powered it up and the large power transistors on the heat sink would get hot
after a time....and the heat sink would also get quite hot. Speakers sounded like they had some DC on them....with a loud thump
Found the manual on Hi-Fi engine,
http://www.mediafire.com/file/b8mlsu7q3pz0bvf/hfe_nad_3140_service.pdf/file ]
and saw a video on youtube saying lots of capacitors dry out
due to their locations near resistors that get very hot, I guess sorta a poor
design. Went in and recapped almost the entire
product save for the (4) large 50V PS caps which appear to check ok.None of
the high power or driver transistors
mounted to the main heat sink were shorted..
Powered on but no audio, and noticed the fuses to Bridge D805 were melted open.
I believe they were ok before.
Replaced them and they started to light up like fiilaments, so shut down,
removed the bridge D805, then checked it, its ok.
There is about a 16 ohm short on the + / - lands where the bridge was. It
seems like something I did maybe is causing this,
like a capacitor in backwards, which I am doing alot of lately for some
reason.
Turns out, yep I put C805 (470/ 63) In backwards ! Capacitor still checks
ok, so will re-use it.
Short is still there though Im guessing R803 is adding in 5.6 ohms or so,
that means theres a 10 ohm short someplace. Q801, 802 arent reading short,
and looks like this becomes a +43V ps feed.
Any ideas out there on what to check next? I am guessing this cap in
backwards caused the voltage applied to a component to be
reverse and its shorted. Or would this be normal with a reversed cap installed,
and putting it in right would be how to fix it?
Steve Hearns
Technotronic Dimensions [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
ALTO DIGAN 2.14-hez windows-os vezérlő programot keresek
Sziasztok! Vásároltam egy ALTO gyártmányú DIGAN 2.14-es digitális equaliser-t. Működik rendesen, de bizonyos funkciók, csak a windows-os vezérlő programmal érhetőek el. A leírásban az ALTO honlapján letölthető programot írja. De valószínű, hogy eltávolították. Amit sikerült kiderítenem, hogy DiganEditor100.exe kell a működéséhez, az USB-s kommunikáció működéshez pedig PL-2303 Driver Installer.exe szükséges. A google sajnos nem talált semmit. Ebben kérném a segítségeteket. Zsolt
LG FFH818 hifi táp gond
Kérem, Harley-D és kozak_g, ne szóljon a topic -hoz!
Tudnátok segíteni?
Lenne  az asztali hifi.
https://elektrotanya.com/lg_ffh-818.pdf/download.html
Valszeg villámos volt.
Ott tartok, hogy a a tápban Q407 Q405 cserével megy a kijelző, a gombokra reagál, de nem hajtja végre a parancsot, tehát nem megy a cd lemezkiválasztás, lemezforgatás, nem indítja a magnó motort, de jelzi, hogy mit kéne csinálnia. A végfok nem megy, a tuner hangol, de nem áll meg az adón...
Az IC704 78R12 nem kap vezérlést a vezérlő lábán kb 0,9V mérek. IC403 kéne vezérelnie, ami nálam egy BU2090 https://pdf1.alldatasheet.com/datasheet-pdf/view/36318/ROHM/BU2090.html
A rajz szerint  HD49783 kéne lenni. Természetesen a két drivernek holt más a bekötése. Az enyém a 1-16 pinen megkapja a 5,6V ot, és a 8 láb a P-CTRL
( szerintem halott chip)
Minek kéne lenni a driver kimeneteken?
