VERTICAL-IC-CATALOG
OTHER - OTHER
11.5 MB
Looking for similar vertical manual?
VERTICAL-IC-CATALOG service manual (1st page)
Preview of VERTICAL-IC-CATALOG [1st page]
VERTICAL-IC-CATALOG service manual (2nd page)
Preview of VERTICAL-IC-CATALOG [2nd page]
    IC CATALOG
Siemens OP177B operátor panel SMD alkatrészének azonositása.
Sziasztok! Fentebb leirt operátor panel alkatrészének azonositásához kérek segitséget. Minden segitséget előre is köszönök. kov-jo
URC-TV01 távirányító
A címben nevezett távirányítóhoz volna szükségem manualra ill kód táblázatra ha valakinek van kérm küldje el nekem Üdv Jancsi
BRG MK 29 magnetofon szíjcsere
T. ! Valaki már hozzányúlt előttem a magnóhoz és nem jól rakta össze. A szíjat kicseréltem, de a mechanika alján lévő, NYÁK kapcsoló érintkezőket nem tudtam a helyére rakni, mert nem látom a helyüket. Ehhez kérek tanácsot. Üdv. gergosz0
Intech LH-5 Heater
Company no longer in business here in the US.
This is a product that heats up and dries wet ski boots,
the board powers 2 big heat guns I guess with programmed cycle
times. No SM or schematic of course.
Main bridge was shorted, seems directly fed from 115V line power.
Replaced the bridge with a thru hole type and hooked up with a variac to power.
 At one point the panel lit up with power, then there was a snap
and thought I saw sparks from the 2 large heat guns in the chassis,
then dead. Fuse blown - bridge shorted again.
Seems like they are using a IC on the boards
to handle the switching side of the SMPS, its a Viper35SP
made by St electronics:
http://www.st.com/content/ccc/resource/technical/document/datasheet/4b/ee/d2/34/15/48/4e/66/CD00144872.pdf/files/CD00144872.pdf/jcr:content/translations/en.CD00144872.pdf
Looks like its obsolete / NLA from what I can see so far. Some on Ebay for purchase.
I think the IC runs straight from the line power, rated at 800V.
Should I try the support components around the IC or try replacing the IC?
I am thinking the heat buildup perhaps caused the smd caps to dry out?
