I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Yamaha psr-s500-as szinti kijelzőjének egyik fele ne működik. Minden egyéb működik rajta, kontrasztot tudom állítani viszont a jobb oldala a kijelzőnek ha feltekerem a kontrasztot teljesen elsötétül ha leveszem a kontrasztot teljesen világos. Segítségeteket kérném, hogy hogyan tudnám megállapítani hogy a kijelzővel vagy a vezérléssel van a gond?
Üdv.: Norbi
sziasztok
először is mindenkitől elnézést kérek, de "hót amatőr" vagyok- egyáltalán nem értek az elektromossághoz. Max, ha fizikálisan lehet csinálni valamit, azt meg próbálom megoldani - volt már, hogy sikerült.
A problémám a következő: van 1 Yamaha KX-670 kazettás deckem, amit hosszasabb ideje nem hallgattam, s miután elővettem, rájöttem, hogy egy 7 perces felvételt 7 perc 24 sec alatt játszik le. A sebesség nem ingadozik. Mivel a készülék összes lehetőségét kihasználva vettem fel annak idején nagy rakat CD-ét kazettára, ezért nagyon vacak lenne ha ezeket elveszteném. Ha vki nem ismerné a készüléket, - dupla szalagfeszítős, 3 fejes, 3 motoros (és egyik sem a kazetta ajtó nyitogatásáért felelős), szalag monitorozási lehetőséggel - (sztem HI-FI minőséggel, bár egész biztos, hogy vannak ennél jobb készülékek is). Úgyhogy megnyúlt a képem, amikor rájöttem a belassulásra. A környékünkön nem nagyon merném senkire rábízni, ha egyáltalán elvállalnák, hisz már felejtős technika.
Az lenne a kérdésem, van-e a sebesség állításnak valamilyen lehetősége, és az esetleg számomra, mint "hót amatőr" számára megoldható e? A kapcsolási rajzot letöltöttem, itt elérhető
http://tatai_tibor.extra.hu/nyomtat/yamaha_kx-670_[et].pdf
de nem sok értelme van számomra, mert nem értek hozzá. Látom, hogy bonyolult, ha kevés szereléssel elérhető vmi, amin állítani kell... Viszont, ha tisztítani kell, vagy esetleg egy csavar segítségével állítani, olyasmit csináltam már és még nem rontottam el készüléket. Úgyhogy, ha vki tud, megkérem segítsen, tanáccsal, - érdemes-e megpróbálni - mit is kellene csinálni, stb...
A válaszokat előre is köszönöm.
Tisztelt Kollégák, lelkes Amatőrök!
Keresem a Yamaha-AX620 házimozi erősítő kapcsolási rajzát, szerviz dokumentációját! Ha esetleg valakinél fellelhető, kérem, ossza meg velem! Köszi előre is: István
