I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
A címben említett erősítő bemenetét túlfeszültség érte, aminek következtében a BD3841FS bemenet választó, a BD3815KS audió processzor, és a BD3812F 2 csatornás hangerő szabályozó (bővítő) IC-k meghibásodtak: túlterhelték a +/- 7V-os tápot, és a vezérlő adatbusz adat és órajel vonalát (DTBD, CKBD).
A hibás IC-k cseréje után a terhelések megszűntek, de a készülék továbbra sem működik, mert a BD IC-ket vezérlő adatbusz órajel és adat vonalára nem jön jel a U-COM processzorból. Minden jelforrás jele eljut a BD3841FS bemenetére, de kimenetein már nincs jel.
A CKBD (pin58) port állandóan fönt van +4,4V-on, a DTBD (pin59) pedig 0V szinten áll. Óra és/vagy adatjel egyiken sem látható.
Ezek szerint a túlfeszültség tönkretette az adatbuszon keresztül a U-COM (pin58, pin59) kimeneti portjait is!
A processzor ettől eltekintve működik, a kvarcoszcillátora megy. Semmiféle hibát nem jelez az öntesztnél. A készülék összes funkciója él, de bemeneti jeleket nem fogad. Hangerőt, hangszínt valóságban nem szabályoz, csak a kijelzőn mutatja a beállított értékeket. A tuner kimenetén van hangfreknenciás jel, de ezt is a BD ic-k kezelik, ezért a végfokra már nem jut belőle semmi (a rádió sem szól).
Mit lehet ilyenkor tenni? Processzort, vagy komplett panelt cserélni, de egyik sem beszerezhető, legalább is én nem találtam forrást.
A U-COM processzor típusa: M3062, de a Yamaha maszkkal ellátva.
Föliratai:
YAMAHA X3605 AO
M3062 VMGP-061FP
A panel (amin a processzor található) föliratai:
X4011-4
CMK I-P3X
A készülék szervizmanuálját letöltöttem.
Érdemi megoldási javaslatokat, processzort, vagy panelt kérek a hozzáértőktől!
A felesleges szószaporítástól kíméljetek!
Fülesmester
A fent nevezett erősítővel a következő a gondom:
Konnektorba bedugva és utána egyből bekapcsolva tökéletesen működik, kikapcsolás után rögtön visszakapcsolva is bekapcsol.
Ha nem egyből bedugás után kapcsolom be, hanem várok 2-3 percet, vagy a kikapcsolás után szintén várok 2-3 percet, már nem hajlandó visszakapcsolni. Kihúzva a konnektorból 2 perc várakozás után az első procedúrát végrehajtva minden gond nélkül működik.
Van valakinek erre valami ötlete, tapasztalata a javítását illetően?
A rajza fent van itt a tanyán, úgyhogy az elvi segítség megvan, csak a hirtelen ráérzés hiányzik.
Minden segítséget előre köszönök.
Krisztián
Üdv Mindenki!
A fenti készülék távirányítója hol megy, hol nem.
A távadó IC típusa JT-7062-2. Az IC körül minden alkatrész átnézve, Infra LED ellenőrizve, a tápot az IC megkapja. A panel erős nagyítás alatt is és a szakadásvizsgálóval is mérve hibátlannak tűnik.
Van rajta egy 3,64MHz-es 3 lábú rezonátor, aminek működését oszcilloszkóp hiányában sajnos nem tudom ellenőrizni, pedig én arra nyanakszom, mert gyakran koppant a padlón.
Szerintetek mi más lehet még?
Az alábbi távok jók elvileg hozzá:
- RAV14 V694130
- RAV205 V4732200
- RAV206 V6940901 és V6940900
Köszi
