YAMAHA CA-2010 SCH
755.1 KB
Looking for similar yamaha manual?
YAMAHA CA-2010 SCH service manual (1st page)
Preview of YAMAHA CA-2010 SCH [1st page]
    YAMAHA CA-2010 CA2010 CA 2010
Yamaha CDX-590 laser adjustments?
I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players. I have changed the laser unit (KSS-210A) but this didn't solve the problem. When I turn the player upside down, it plays the problematic CDs without a problem. That's why I think the laser needs adjustment. I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590. It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual. Here is a picture of the PCB. http://www.volny.cz/hwtest/PCB.JPG Here are the "test mode" sections of the service manual. http://www.volny.cz/hwtest/TM1.GIF http://www.volny.cz/hwtest/TM2.GIF In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one. So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode. It didn't help. Mode 1 - only a short blink of two horizontal dashes on the display and thats it Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on Mode 3 - seems to be very short as mode 1 I think I'm missing something ... Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser? Or maybe the problem is not the laser?
Yamaha M-45 a működő oldal nagyon meleg ??!!??, a rossz oldal szétégett újraépítve is füstöl
Sziasztok! Kaptam egy Yamaha-M45 asztali sztereó erősítőt. Az egyik oldalát sikertelenül már javítgatták . Innen az összes tranzisztort , szétégett ellenállást kidobtam , majd újakat tettem be. Végfoktranyókat nem kötöttem bele , mert a jó oldalra is kíváncsi voltam . - Méregetés közbe a rossz oldalon Q115 jelű tranzisztor kicsit megfüstölt. Ez mitöl lehet? - A működő oldalon próbáltam összehozni a manualba leírt beállításokat , miszerint R156 nál 5mV+-1mV , bekapcsolt Auto "A-Class" nál pedig 60mV+-30mV , ez össze vissza mászkál ha kikapcsolva beállítom 5mV ra akkor bekapcsolva 25 töl nem lesz több. Ha feltekerem 35mV re akkor kikapcsolva 11mV és erősen melegszik! - Jó odlaon -1.1V körül lehet mérni a potin a rossz oldalon 2V fölött mérhető , de a hiányzó végtranyók is ludasak lehetnek. Adjatok tanácsot. Az újabb erősítők máshogy vannak hajtva jóval egyszerűbben lehet hogy valami elkerülte a figyelmem. Projekt: - Megszüntetni a felesleges melegedést ha kell . - Kitalálni miért füstölt meg a Q115 . Rajz link: http://elektrotanya.com/yamaha_m-45_stereo_power_ampl.pdf/download.html
Yamaha RX-V459 nem kapcsol be
Tipikus yamaha hibával indult a dolog, c3015 (22nf) kondi csere és már működik is.
De ez csak 1 napig tartott, másnap ismét nem indul.Újból szétszedve az r3034 ellenállás kiégve, a c3015 jó.
Ellenállás cserélve megfelő értékre, de semmi.Ezután cseréltem még c3016 (50v 1uf) és az ic302 (tc4013bp), de ezek után sem ad élet jelet.
Esetleg valaki megtudná mondani hogy mi mehet még tönre ezekben a tápokban?
Velemenyek a Yamaha P2040 erositorol
Sziasztok. Adott a cimbeli erosito (vagy inkabb csak erolkodo). Ugy nez ki, mintha egy profi, 4 csatornas, hidalhato erosito lenne. Nagy csalodas volt, amikor beleneztem a szervizkonyvbe. 2 drb sztereo STK van benne, 2x35w talan fejenkent. Itt kezdett erdekelni a dolog, kivancsi voltam hogyan oldja meg egy STK 2 csatornajanak a hidalasat......  Hat, sehogy. Barhogy is neztem, a 2ch/4ch kapcsolo a hatlapon csak annyit csinal, hogy megnoveli a tapfeszt. De hogy a kapcsolo 2ch pozitiojaban miert ne lehetne mind a 4 csatornat hasznalni, nem ertem. Hisz a koppanasgatlo relek is egyszerre huznak meg, a bemenetek is aktivak maradnak...
Na mindegy, csalodas ez az erolkodo. Olyan, mintha ugyanabban a csonakban evezne a Bluetech-el es tarsaival, amiket megspekeltek egy blustucc-al, memoriakartya olvasoval, esetleg fm radioval. Csak hat a nev, na....
Mindezt azert kerdem, mert talaltam egy ilyen elado erolkodot, es meglodult a fantaziam, hogy mi mindent tudnek kezdeni a dobozaval....
