I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Sziasztok. Adott a cimbeli erosito (vagy inkabb csak erolkodo). Ugy nez ki, mintha egy profi, 4 csatornas, hidalhato erosito lenne. Nagy csalodas volt, amikor beleneztem a szervizkonyvbe. 2 drb sztereo STK van benne, 2x35w talan fejenkent. Itt kezdett erdekelni a dolog, kivancsi voltam hogyan oldja meg egy STK 2 csatornajanak a hidalasat...... Hat, sehogy. Barhogy is neztem, a 2ch/4ch kapcsolo a hatlapon csak annyit csinal, hogy megnoveli a tapfeszt. De hogy a kapcsolo 2ch pozitiojaban miert ne lehetne mind a 4 csatornat hasznalni, nem ertem. Hisz a koppanasgatlo relek is egyszerre huznak meg, a bemenetek is aktivak maradnak...
Na mindegy, csalodas ez az erolkodo. Olyan, mintha ugyanabban a csonakban evezne a Bluetech-el es tarsaival, amiket megspekeltek egy blustucc-al, memoriakartya olvasoval, esetleg fm radioval. Csak hat a nev, na....
Mindezt azert kerdem, mert talaltam egy ilyen elado erolkodot, es meglodult a fantaziam, hogy mi mindent tudnek kezdeni a dobozaval....
Szevasztok Kollégák!
Bótoltam a fentit, na nem gitározás céljára, ahhoz én kevés lennék, hanem vonal szintű MP3 hanganyag bejátszására alkalmanként egy kis közösségben.
Azért is tetszett meg, mert könnyen lehet hurcolni villany bringával is.
Kipróbáltam, működik is rendesen.
Nézzük már meg, hogy mi mohog benne, miután rajzot nem talált hozzá a gugli barátom, csak egy használati utasítást.
Hangszóró.
Nem centiztem le, ez van felírva rá:
F.S.T F20615 4ohm NOM: 15W MAX: 30W M 2X061
A használati utasítás szerint:
15Wr.m.s. (T.H.D. 10%) 20cm (4ohm)
Nézzük meg, hogy mekkora teljesítmény jön ki belőle.
Hátul az adat tábláján: 20 WATTS.
Power Consuption 20W.
Jó, ha a hangszóró 4 ohmos betettem a helyére egy 4 ohmos ellenállást, és azt néztem szkóppal.
A bemenetre 1KHz szinuszt adtam.
Növelve a kimenő jel nagyságát cirka 14Vpp körül kezdett látható torzítás lenni.
No, ha ezt visszaszámolom 4 ohmmal, az bizony mindössze 6.16W.
Megnéztem, hogy mi van benne.
3db IC-t találtam:
IC1, és IC2 C4558C
IC3 végfok, nem olvastam le, ehhez teljesen szét kellett volna szedni, de egy TO-220 tokozású 5 lábú IC.
Amiket sikerült beazonosítanom: Pin5: Vcc; Pin3: Vee; Pin4: Out.
Megnéztem a tápfeszültségeket.
+-16.7V terhelő ellenállás, és kimenő jel nélkül, szkóppal nézve jók.
A tápfeszültségek 2200uF 25V-tal szűrve oldalanként.
A hálózati trafó jó kicsike, nem centiztem le, mert ahhoz megint teljesen szét kellett volna szerelni az erősítőt.
Tudom, hogy kitaláltak ügyességeket, idéznék egy interneten talált mondatot:
"RMS, P.M.P.O., tényleges, zenei, szinuszos ilyen teljesítményekről hallottam eddig, és egyedül csak a PMPO-ról tudom hogy nagy 'csalás' - Peak momentary power output - pillanatnyi maximum teljesítmény."
Nekem az egészről az jön be, hogy láttam, hogy a piacon árultak kicsi rádiókat, amelyek a Szokolnál alig voltak nagyobb méretűek, és öles betűkkel rá volt biggyesztve, hogy 200W.
Elhiszem, hogy megetették a nagyérdeművel azt a zenei teljesítmény mizériát, de hogy egy 6W-os Yamaha erősítőre 20W-os táblát akasszanak fel, hát az egy kicsit nekem sok.
Mi a véleményetek?
Üdv.: Pista.
Üdv. Mindenkinek!
Fent nevezett erősítő nem kapcsol be. Készenlét nincs. A bekapcsoló gombot megnyomva két(gyors egymásutáni)relé kattanást hallani.Passzív méréssel a tápban és a végfokban a félvezetők és a passzív alkatrészek jónak tünnek.
Jó lenne hozzá a frissítő szoftvert: DSP_FLASHER Vx600 letölteni,de nem találom sehol sem.
Kellene valamilyen segítség vagy tapasztalat.
üdv.
