I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
sziasztok
először is mindenkitől elnézést kérek, de "hót amatőr" vagyok- egyáltalán nem értek az elektromossághoz. Max, ha fizikálisan lehet csinálni valamit, azt meg próbálom megoldani - volt már, hogy sikerült.
A problémám a következő: van 1 Yamaha KX-670 kazettás deckem, amit hosszasabb ideje nem hallgattam, s miután elővettem, rájöttem, hogy egy 7 perces felvételt 7 perc 24 sec alatt játszik le. A sebesség nem ingadozik. Mivel a készülék összes lehetőségét kihasználva vettem fel annak idején nagy rakat CD-ét kazettára, ezért nagyon vacak lenne ha ezeket elveszteném. Ha vki nem ismerné a készüléket, - dupla szalagfeszítős, 3 fejes, 3 motoros (és egyik sem a kazetta ajtó nyitogatásáért felelős), szalag monitorozási lehetőséggel - (sztem HI-FI minőséggel, bár egész biztos, hogy vannak ennél jobb készülékek is). Úgyhogy megnyúlt a képem, amikor rájöttem a belassulásra. A környékünkön nem nagyon merném senkire rábízni, ha egyáltalán elvállalnák, hisz már felejtős technika.
Az lenne a kérdésem, van-e a sebesség állításnak valamilyen lehetősége, és az esetleg számomra, mint "hót amatőr" számára megoldható e? A kapcsolási rajzot letöltöttem, itt elérhető
http://tatai_tibor.extra.hu/nyomtat/yamaha_kx-670_[et].pdf
de nem sok értelme van számomra, mert nem értek hozzá. Látom, hogy bonyolult, ha kevés szereléssel elérhető vmi, amin állítani kell... Viszont, ha tisztítani kell, vagy esetleg egy csavar segítségével állítani, olyasmit csináltam már és még nem rontottam el készüléket. Úgyhogy, ha vki tud, megkérem segítsen, tanáccsal, - érdemes-e megpróbálni - mit is kellene csinálni, stb...
A válaszokat előre is köszönöm.
Sziasztok. Adott a cimbeli erosito (vagy inkabb csak erolkodo). Ugy nez ki, mintha egy profi, 4 csatornas, hidalhato erosito lenne. Nagy csalodas volt, amikor beleneztem a szervizkonyvbe. 2 drb sztereo STK van benne, 2x35w talan fejenkent. Itt kezdett erdekelni a dolog, kivancsi voltam hogyan oldja meg egy STK 2 csatornajanak a hidalasat...... Hat, sehogy. Barhogy is neztem, a 2ch/4ch kapcsolo a hatlapon csak annyit csinal, hogy megnoveli a tapfeszt. De hogy a kapcsolo 2ch pozitiojaban miert ne lehetne mind a 4 csatornat hasznalni, nem ertem. Hisz a koppanasgatlo relek is egyszerre huznak meg, a bemenetek is aktivak maradnak...
Na mindegy, csalodas ez az erolkodo. Olyan, mintha ugyanabban a csonakban evezne a Bluetech-el es tarsaival, amiket megspekeltek egy blustucc-al, memoriakartya olvasoval, esetleg fm radioval. Csak hat a nev, na....
Mindezt azert kerdem, mert talaltam egy ilyen elado erolkodot, es meglodult a fantaziam, hogy mi mindent tudnek kezdeni a dobozaval....
Fenti erősítő feladja a leckét...
Bekapcsolás után 1mp múlva kikapcsol. Szervizmódban elindítva (FM/AM gomb+8-as gomb hosszan nyomva), úgy bekapcsolva,
DC PRT 000 B kijelzéssel indul.
Amit megnéztem: 22nF /630V a kis tápegységben 4013-at cseréltem. Tápfeszek +/-50V a végfokon OK. Végfok kimenet DC egyik csatorna -40mV, másik -28mV .Végfokban a tranzisztorokon egyenfeszek a service manualban előírtak.(füst, korom, melegedés) semmi.
6. pontban (6 gomb menüben) egyértelmű DcPRT 000 mindegyik almenüben 6.1, 6.2 stb... Az 5V,+/-15V ellenőriztem. DC prot lábon C147 kondin 0V van. Nem értem miért reklamál kimeneti DC feszültség jelenlétére, amit szkóppal ellenőrizve nem is észlelek.a kimeneten a -40mV miatt kapcsolhat ki?
Kifogytam az ötletekből.
Ha lenne valakinek ötlete, megköszönném.
Szabi
