Hi!
Hoznának egy ilyet.
Valszeg végfokos.
Érdemes belebonyolódni, lehet kapni megbízható ilyent?
kösz
I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Szisztok!
Hát sajna fenti hangfalam egyik magasa elszállt.:(
Tudnátok segíteni tekercselésben címmel,tanáccsal mert feltétlen meg szeretném csináltatni!
Üdv:Mika.
Van nekem egy 1995-ben vásárolt Yamaha PSR-510 amatőr (tehát nem profi zenészek használják) szintetizátorom aminek a fejhallgató és az AUX kimenetének ugyanaz a csatlakozója.
Laikusként én azt szeretném megérteni, hogy ez hogyan lehetséges, mert amikor a fejhallgatót bedugom ebbe a csatlakozó aljzatba (amikor is a szinti hangszórói elnémulnak), attól kezdve a szinti hangerő szabályzó gombjával tudom a fejhallgató hangerejét is szabályozni.
Én idáig úgy tudtam, hogy az AUX kimenet jele egy stabil volt illetve mV tartományba esik, amit nem szoktak és nem is lehet változtatni azért, hogy a hozzá kötött erősítő bemenő elektronikáját véletlenül se tudja károsítani.
De ebben az esetben a hangerő szabályzó gomb pont ezt teszi.
(Nem feltételezem, hogy ennek a kimenő áramkörnek lenne egy spéci áramköre kizárólag arra a célra, hogy detektálja, hogy fejhallgató vagy erősítő van-e az aljzatba bedugva.)
Tehát, mit tanácsoltok nekem ez ügyben? Pl. hová állítsam a hangerő szabályzó lineáris potiját ha a szintit egy erősítőhöz akarom kötni?
Van nekem egy nagyon érzékeny Fluke 87-es DVOM voltmérőm, azzal tudnék a csatlakozón feszültséget mérni ha ez segítene, de engem leginkább egy olyan megoldás nyugtatna meg végleg ha egy hozzáértő szakember adna hozzá egy valódi AUX kimenetet néhány forrasztással a megfelelő helyen.
De várom a javaslataitokat. A szerviz manualt le lehet tölteni innen az elektrotanyáról, az utolsó oldalán láttam a legjobb ábrázolását ennek az áramkörnek.
