Yamaha psr-s500-as szinti kijelzőjének egyik fele ne működik. Minden egyéb működik rajta, kontrasztot tudom állítani viszont a jobb oldala a kijelzőnek ha feltekerem a kontrasztot teljesen elsötétül ha leveszem a kontrasztot teljesen világos. Segítségeteket kérném, hogy hogyan tudnám megállapítani hogy a kijelzővel vagy a vezérléssel van a gond?
Üdv.: Norbi
I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Sziasztok!Fent említett erősítő,még várakozás,hideg indítás,bármilyen praktikára sem hajlandó bekapcsolni.Még nem érkezett meg hozzám,de korábban még elindult egy-kétszer,de most már abszolút nem csinál semmit.Olvasgattam itt mások eseteit,itt is kondi lesz valószínű,vagy még mást is tönkre vághatott?Csak az érdekelne,hogy elérhető-e hozzá minden olyan alkatrész amit esetleg cserélni kell.Válaszaitokat,segítségetek előre is köszönöm!Üdv Sakee.
Tudnátok segíteni?
Lenne egy ilyen ketyere:
https://elektrotanya.com/yamaha_rx-v1400_v1400rds_v2400_v2400rdx_sm.pdf/download.html
Ha ha tápra rakom akkor a stby trafo által elállított feszek megvannak a proci panelon(5M2, stb.)
Semmi nem jelzi hogy stby -ban van, nem tudom, hogy kell e, hogy jelezze valami egyáltalán.
Indítom, a táp relé kattan a főtrafo felé kapcsolja a 230V majd leold a relé. A kijelző egy pillanatra se éled.
Valami durva dolog lehet benne, mert minimum egy kijelző éledés, egy protect felirat kéne...Vagy nem??
Érdemes tovább mélyedni, mert semmihez nem lehet hozzáférni, annyira be van építve... ??
Kösz
