I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Üdv Mindenki!
A fenti készülék távirányítója hol megy, hol nem.
A távadó IC típusa JT-7062-2. Az IC körül minden alkatrész átnézve, Infra LED ellenőrizve, a tápot az IC megkapja. A panel erős nagyítás alatt is és a szakadásvizsgálóval is mérve hibátlannak tűnik.
Van rajta egy 3,64MHz-es 3 lábú rezonátor, aminek működését oszcilloszkóp hiányában sajnos nem tudom ellenőrizni, pedig én arra nyanakszom, mert gyakran koppant a padlón.
Szerintetek mi más lehet még?
Az alábbi távok jók elvileg hozzá:
- RAV14 V694130
- RAV205 V4732200
- RAV206 V6940901 és V6940900
Köszi
Tisztelt Kollégák!
Napokban hozzám került egy cd hibás Yamaha CRX-M5 hifi torony. A hibajelenség az volt, hogy nem olvasta be a lemezeket, csak forgatta azokat.
Mérések, tesztek alapján a lemezforgató és a fej mozgató motor is hibás volt. Kicseréltem mindkettőt. Optikát megtisztítottam.
3 tálcás cd játszóval rendelkezik a készülék. Érdekesség, hogy ezek után csak az egyik tálcából volt hajlandó beolvasni a lemezt. Többször próbáltam állítani a lemeztányér magasságát. Azt eredményezte, hogy mindig másik tálcáról tudta beolvasni a lemezt, pedig az egész mechanika együtt mozog, amikor tálcát választ a hifi.
Nehezen sikerült beállítanom, most mindegyik tálcáról beolvas, viszont nem mindig olvas be elsőre és ha léptetek a zeneszámok között nem mindig találja meg a track-et (vagy csak nehezen).
Ha beolvasta a lemezt és nem léptetem, akkor szépen végig lejátssza a lemezt.
Észrevettem még azt, hogy a fej mozgató motor folyamatosan oda-vissza forog lejátszás közben. De nem nagy fordulatokat tesz, inkább olyan mintha remegne.
A motorvezérlő IC tápját biztosító tranzisztor elég rendesen melegszik. Motorvezérlő IC-t cseréltem. Rendeltem bele egy új lézer fejet is, de azzal be sem olvasott, akármit csináltam vele.
Ha van ötlete, tanácsa valakinek, azt szívesen fogadnám!
A fenti erősitő nem mutat életjelet.
A C405 cserélve-soros tápkondi,mkp kondi lett helyette..
A gondom az,hogy mitől kellene behúzni a relének?
Valaki elemezné esetleg?
A rajz 49. oldalán van a táprajz.
A fet helyére mit tehetek még,illetve hogy tudnám kényszerinditani esetleg?
innen a tanyáról letölthetö a rajz:
https://elektrotanya.com/yamaha_rx-v450.pdf/download.html
Azt az egy oldalt sajnos nem tudom kimásolni chromeból, és feltölteni ide
Ha valaki tudna segiteni....
Köszönöm.
A megoldás:
A CB402 és CB407 csatlakozók fel voltak cserélve....
Mégiscsak műhiba volt,de hozzám igy érkezett.
Visszaállitva mindent,amit feleslegesen cseréltem,bekapcsol a gép.
A feszültségek pedig a soros induktivitáson(Táptrafó) keresztül realizálódtak...
Most derül ki a többi probléma majd.
Külön köszönöm mindenkinek a segitséget.
