Üdvözletem!
Van a tárgyban említett erősítő amihez szükségem lenne egy magyar nyelvű használati utasításra. Hátha valakinél lakozik egy. Segítségeteket előre is köszönöm.
üdv Tamás
I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Vettem a cimben szereplö erösitöt.
Kissé hiányos állapotban,azzal a céllal hogy csinálok belöle egy asztali sztereo erösitöt.
A hiányossága a front elölap panal,de ez nem is kell.
Tehát a probléma,hogy a jobb illetve a bal oldali front csatornán ,a kimeneten kinnt van a +42 volt.
Se melegedés,se égésnyom nem találhato a panelen.
Az a furcsa hogy mind a kettö csatorna ugyanezt produkálja.
Kezdek felcsomozni,mert nem egy szerelöbarát készülék.
Végfok tranzisztorok kimérve,meghajtok kimérve.
Minden segitökész választ szivesen fogadok.
üdv:atis
Üdvözlet Mindenkinek!
Az adott erősítő időnként meggondolja magát és nem kapcsol be.
A tápot végigmérve minden rendben van.
Ha lenne valakinek valami ötlete, azt előre is köszönöm.
