YAMAHA RX-V565 AX-V565 SM
19.7 MB
Looking for similar yamaha manual?
YAMAHA RX-V565 AX-V565 SM service manual (1st page)
Preview of YAMAHA RX-V565 AX-V565 SM [1st page]
YAMAHA RX-V565 AX-V565 SM service manual (2nd page)
Preview of YAMAHA RX-V565 AX-V565 SM [2nd page]
    YAMAHA RXV-565 RXV565 AXV565 RXV 565 AXV RX V565 AX RX-V565 AX-V565
YAMAHA RX-V630RDS Kikapcsol 1 sec után DIAG Code :PS PRT 23 C (megoldva)
A címben említett típusú erősítő 1 sec után visszatér STAND-BY-ba.
A DIAG mode megy, és ezt a hibát dobja : PS PRT 21 C
Az biztos, hogy úgy lett bekapcsolva, hogy az impedancia választó középen volt (kölcsön volt adva). Átállítottam normál-ba (8Ohm), de nem változott semmi.
Szerintetek végfok lehet a gond ? Ahogy nézem a 21-es érték rossz, mert 28-43-ig kellene lennie.
Előre is köszönöm
Yamaha CDX-590 laser adjustments?
I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players. I have changed the laser unit (KSS-210A) but this didn't solve the problem. When I turn the player upside down, it plays the problematic CDs without a problem. That's why I think the laser needs adjustment. I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590. It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual. Here is a picture of the PCB. http://www.volny.cz/hwtest/PCB.JPG Here are the "test mode" sections of the service manual. http://www.volny.cz/hwtest/TM1.GIF http://www.volny.cz/hwtest/TM2.GIF In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one. So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode. It didn't help. Mode 1 - only a short blink of two horizontal dashes on the display and thats it Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on Mode 3 - seems to be very short as mode 1 I think I'm missing something ... Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser? Or maybe the problem is not the laser?
Yamaha HTR-5630RDS hangosítás/halkítás esetén job/bal oldali hangfal "össze-vissza" elnémul
Sziasztok! A problémám a következő: Jelenség 2 hónapja: bekapcsolom az erősítőt és valamelyik oldali hangfal nem szól. Hangosítok, és egy bizonyos (mindig változó) hangerő után "bekapcsol" a hangfal. Aztán visszahalkíthatom, és szépen szól sztereóban minden. Jelenség most: bekapcsolom az erősítőt és valamelyik oldali hangfal nem szól. Hangosítok, és egy bizonyos (mindig változó) hangerő után "bekapcsol" a hangfal. Aztán visszahalkítom, kikapcsol.. és mindezt össze-vissza. Aztán ha hagyom, akkor mintha pár perc után "bemelegedne", és minden OK. (ha van türelmem megvárni) Szóval haldoklik. Hogy fogjak hozzá a hibakereséshez? (zöldfülü vagyok, de megfelelő távsegítséggel csodákat tudok tenni :) ) Köszi előre is! coyote
yamaha natural sound av receiver RX-V361 használati utasítás
Üdvözletem! Van a tárgyban említett erősítő amihez szükségem lenne egy magyar nyelvű használati utasításra. Hátha valakinél lakozik egy. Segítségeteket előre is köszönöm. üdv Tamás
