I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Adva van a megnyitóban említett erősítő, amelyet nem lehet bekapcsolni. A táp megoldását nem ismerem. Ha valamelyikőtöknek volt már ilyen problémája szívesen venném a segítségét.
Üdv.Ckó
Helló.
Van egy Yamaha K-M77 kazettás deckem, ami a követekező érdekes működést produkálja: ha egy műsoros kazettát teszek az A-ba, akkor tökéletesen lejátsza, ha pedig a B-be rakom akkor a magas hangok eltűnnek. Ha viszont a deck-el felvett kazettát rakok be akkor meg pont fordított a jelenség, hogy a B szépen lejátsza, az A-ba meg eltűnnek a magas hangok. (A dolby mindig ki van kapcsolva) A B-vel lehet felvenni kazettára.
Mitől lehet ez?
Kaptam egy Yamaha-M45 asztali sztereó erősítőt. Az egyik oldalát sikertelenül már javítgatták . Innen az összes tranzisztort , szétégett ellenállást kidobtam , majd újakat tettem be. Végfoktranyókat nem kötöttem bele , mert a jó oldalra is kíváncsi voltam .
- Méregetés közbe a rossz oldalon Q115 jelű tranzisztor kicsit megfüstölt. Ez mitöl lehet?
- A működő oldalon próbáltam összehozni a manualba leírt beállításokat , miszerint R156 nál 5mV+-1mV , bekapcsolt Auto "A-Class" nál pedig 60mV+-30mV , ez össze vissza mászkál ha kikapcsolva beállítom 5mV ra akkor bekapcsolva 25 töl nem lesz több. Ha feltekerem 35mV re akkor kikapcsolva 11mV és erősen melegszik!
- Jó odlaon -1.1V körül lehet mérni a potin a rossz oldalon 2V fölött mérhető , de a hiányzó végtranyók is ludasak lehetnek.
Adjatok tanácsot. Az újabb erősítők máshogy vannak hajtva jóval egyszerűbben lehet hogy valami elkerülte a figyelmem.
Projekt:
- Megszüntetni a felesleges melegedést ha kell .
- Kitalálni miért füstölt meg a Q115 .
Rajz link: http://elektrotanya.com/yamaha_m-45_stereo_power_ampl.pdf/download.html
