I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Protect modban van mert a kimeneten van DC feszültség, mindkét oldalon megjelenik a + táp (+48V), ha a Left oldalon kiveszem a PNP,NPN végtranzisztor bázis ellenállásait(4R7/0.25W) és csipeszekkel az RCA bemenet GND-jét összekötöm a GND-vel(házzal) akkor a Right oldal 0V, majd a jobb oldal harmadszori bekapcsolas után szintén 0V-ra lecsökken, és a protect mód megszünik.
Ha visszarakom a Left bázis ellenállásait (de a csipeszelés marad) akkor mindkét oldalon -48V jelenik meg, de van néha hogy +48V ra állnak be.
Mérve minden alkatrész jó.Feszültségek a végfokban sehol se jók. Mindenhol +48V vagy -48V van.
Eredetileg az elôerôsítô tápja (+15.8V)-ot elôállító Q133=2SK30 (TO-92) szét volt pukkanva meg a melette levô D109=ZPD16-os tulfeszültség védô zárlatos volt.
Ha kiveszem a Left oldal végtranzisztorait akkor is van a kimeneten +DC feszültség de csak +4V.Na itt megállt a tudomány..
Sziasztok, a fenti Yamaha S900-nak a kijelzője megbolondult és hiányosan adja be a képet, ebben kérnék tanácsot. Köszönettel. Üdv.: Imre
Sziasztok. Elozmenyek: az amplituner hibasan kerult hozzam, nem adott semmi eletjelt. A vegerosito egyik csatornajanak vegtranzisztorai voltak zarlatosak, az egyik meghajto ossze-vissza vezetett, es az egyik vegtranzisztor emiter ellenallasa volt megszakadva. Sajnos az eredeti tranzisztorokat csak eleg borsos aron lehet beszerezni, igy a hibas vegtranzisztorok helyebe BD249c/250c paros kerult, meghajtoknak pedig a 2SA1013/2SC2383 paros. Ezek utan a javitott csatornan mert feszltsegek nem igazan egyeznek a szervizkonyben szereplokkel. A mert feszultsegeket rairtam a beszkennelt rajzra. VR102 - bol beallitottam TR122 bazisan a -0.5v-ot, de a vegtranzisztorok bazisan csak +-0.44v van, az emiterellenallason nem merheto feszultsegeses. Ennek ellenere a csatorna mukodik/szol egy nelkulozheto probahangszorot rakotve. Sajnos szkopom nincs, igy nem tudom megvizsgalni a jelatvitelt. Kerlek adjatok valami tanacsot hol lehet a gubanc?
