Kérdezném,hogy van-e valakinek Acer al1715sm lcd monitorhoz vezérlőpanelje?
Sziasztok acer al 1731-es monitorhoz keresnék AM939 VL903-as controll panelt illetve AM939 VP903-as táp panelt aki tud segiteni kérem jelezze. üdv
A helytelenül elnevezett topik felfüggesztésre kerül! Nem lehet majd hozzászólni, amíg ki nem javítod a címet.
A hibás cím utólagos javítása a "Szerkesztés" fülre kattintva végezhető el."
Hi,
I'm sorry for writing in English, but I don't understand any single word in Hungarian and I couldn't find an English subforum there.
I have changed the LVDS controller and now it's working perfectly, but I need help with the backlight. The CCFL lamps in the screen are OK. I connected the screen to another inverter (from BenQ T705, made on TL1451 which also has "protect" function) and the backlight worked perfectly. Again, I connected other screen to the malfunctioning ILPI-075 inverter and the screen also goes blank.
I changed all THT electrolytic capacitors on the board, but not much has changed. Before, the backlight was turning off almost immediately, now it glows for 1-2 seconds and then turns off.
The HV side of inverter transformers is about 470 ohm, they look OK.
I measured random capacitor in the +16V line, which is supplying the high voltage inverters.
We can see how the voltage went down while the backlight was powered on.
Also, the ON/OFF signal on ICL837's pin 8 is always present after powering up the power supply, even after the backlight turns off.
I don't have any idea what to check now..
T. Kollégák!
Keresem a tárgybeli monitor inverter rajzát. Az a gond, hogy az OZ960G-s ic megkapja az indításhoz szükséges 5V-t, meg is jön a driver jel, de a trafókra a táp nem jut el, mert a kapcsoló dual fetek nem kapnak vezérlést. Elég nehéz végig követni, hogy mi miből következik.
Előre is köszönöm.
Üdv,
Elbandi.
