AIR KING PRODUCTS 701 SCH
42.2 KB
Looking for similar air manual?
AIR KING PRODUCTS 701 SCH service manual (1st page)
Preview of AIR KING PRODUCTS 701 SCH [1st page]
AIR KING PRODUCTS 701 SCH service manual (2nd page)
Preview of AIR KING PRODUCTS 701 SCH [2nd page]
S/PDIF átalakító optikairól RCA-ra - MEGOLDVA
Sziasztok! Szeretnék alaplapot cserélni a film nézős számítógépemnél, a legnagyobb probléma az jelenleg, hogy a régi alaplapon RCA koax sdpif kimenet volt, amit a házimozi erősítőre kötöttem. Az új alaplapon csak optikai spdif kimenet van, ugyan az erősítőn van optikai bemenet, de fény szálam nincs hozzá. Nincs valami fiókból összedobható SPDIF átalakító, ami csak a ,,közeget'' alakítja át? (tehát nem D/A átalakítót akarok)
advice for repairing a DBX BX3 power amp (fused power transistor)
i have a very nice vintage DBX BX3 amp on which at least one channel fused.
power transistors literally burned down.
it is a very nice piece of hardware (4 channels with BTL capability 4x125W or 2x300W)
I would like to fix it myself. Having an electronic engineering degree, i think I should be able to undertake that venture but I never practiced (i've been in software for the last 40 years...)
So I need some guidance on the methodology to diagnose and track what went wrong.
I do have a scope, signal generator and I guess all required tools, as well as the schematics of the amp.
what I need is some help on locating the key parameters to measure and how to incrementally explore the different stages of the amp to find the faulty sections.
I guess I need to isolate the different sections of the amp but then, what ?
any help and advice will be highly appretiated.
repair sony amplifier str-de254
Want to share: Have downloaded the schematics from this forum to help repair the amplifier of a friend. Turned out that Sony decided to route the earth through the chassis, even the earth between the various supplies. When one takes the main board out of the chassis and switches the amp on, there are up to 20 volts difference between the eart (and hence reference) of the pre-amps and the main amps. Luckily the amp goes into protection but from a design point of view it is not nice to rely on screws and aluminum face plates to conduct up to 0.2 amps of current from one supply to another. What I did is solder wires to every eart point and connected them on the main board to make it stand alone and not rely on conducting current through the chassis anymore. Bad design, simple repair but took some digging in the schematics to find out what exactly was going on!
repair Marshall Acton 2
Hi,
My column Marshal Acton 2 , is dead . Power suplyy is it ok ... 18 V , but not light and not power on.
I need some help, and i try to find schematic !
Do tou can help-me ?
Best regards
