Hi,
My column Marshal Acton 2 , is dead . Power suplyy is it ok ... 18 V , but not light and not power on.
I need some help, and i try to find schematic !
Do tou can help-me ?
Best regards
Rákötöttem a Samsung led tv-t az AUX csatornára, de folyamatosan megy a rádió halkan.Elég idegesítő filmnézés közben amikor párbeszédes rész van.Esetleg valakinek valami ötlete, hogy mi lehet a baj?
Köszönöm előre is.
Szép napot
Want to share:
Have downloaded the schematics from this forum to help repair the amplifier of a friend.
Turned out that Sony decided to route the earth through the chassis, even the earth between the various supplies.
When one takes the main board out of the chassis and switches the amp on, there are up to 20 volts difference between the eart (and hence reference) of the pre-amps and the main amps.
Luckily the amp goes into protection but from a design point of view it is not nice to rely on screws and aluminum face plates to conduct up to 0.2 amps of current from one supply to another.
What I did is solder wires to every eart point and connected them on the main board to make it stand alone and not rely on conducting current through the chassis anymore.
Bad design, simple repair but took some digging in the schematics to find out what exactly was going on!
Hi all,
I need a little help to repair my Akai PM-750 amplifier (part of system mx-750).
The voltage selector has broken and I don't know wich wires shoud I put together to get it work under 240V.
Service manual is no help, they just give spares parts...
Huge thanks to who could help me :-)
