AIWA CD-FR929 SM
CAR-AUDIO - SERVICE MANUAL
574.9 KB
CAR-AUDIO
AIWA CD-FR929 SM service manual (1st page)
Preview of AIWA CD-FR929 SM [1st page]
AIWA CD-FR929 SM service manual (2nd page)
Preview of AIWA CD-FR929 SM [2nd page]
    AIWA CDFR-929 CDFR929 CDFR 929 CD FR929 CD-FR929
JAPAN FM vs. EU FM
Hi!
 Használt már Valaki ilyet?
https://www.aliexpress.com/item/Car-Frequency-Antenna-Radio-FM-Band-Expander-For-Japanese-Autos-Signal-Reduce-Radio-FM-88-108/32798944228.html?spm=2114.search0604.3.1.72892184QavWAg&ws_ab_test=searchweb0_0,searchweb201602_7_10065_10068_319_317_10696_10084_453_10083_454_10618_10304_10307_10820_10821_537_10302_536_10902_10059_10884_10887_321_322_10103,searchweb201603_59,ppcSwitch_0&algo_expid=4d303015-6bb6-4982-9ffb-5feb5ea75beb-0&algo_pvid=4d303015-6bb6-4982-9ffb-5feb5ea75beb&transAbTest=ae803_4
Köszi
chine USB ,BT modulator board sound interference
Hi, I tried  embed a USB modulator on the radio for bmv e46, I'm connected to the TEA 0676, but I have a low level of interference, how to get rid of it
the connection is the following in the picture...
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
DVS-7150V DVD olvasófej csere után csak röviden pörgeti fel a lemezt
Régóta vagyok itt csendes tag, de most a kollektív tudásotokat szeretném segítségül hívni.
A háttér:
A készülék egy Ford navigációs fejegység. Név szerint Blaupunkt Travelpilot NX. Ebben egy DVD lemezen van a navigációs adatbázis. Idővel a DVD olvasó fej elgyengül és egyre nehezebben olvassa a térkép DVD-t. Gondoltam kicserélem benne az olvasó fejet. A meghajtó egység típusa DVS-7150V és ebben egy KDP-1C típusó olvasófej való. Rendeltem is egyet Kínából, persze az egyik legolcsóbbat, de jónak tűnő eladótól. Előtte felhívták a figyelmemet, hogy általában nem szoktak működni ezek a fejek. Ennek tudatában rendeltem. Hozzáteszem, hogy még így is kétszer annyiba kerül a fej, mint egy PC-s DVD író6olvasó egység, tehát akár működhetne is.
Beszereltem az új olvasófejet. A védő rövidzárat eltávolítottam, de hiányos ismereteim miatt az elektrosztatikus védelemre nem fordítottam különösebb figyelmet. Persze nem működik, nem is ez a gond, de szeretnék biztos lenni benne, hogy fej hiba.
A kérdés:
Tehát az van, hogy a kicserélt DVD olvasó fejjel az egység alaphelyzetbe (legbelülre) állítja a fejet ha nem ott volt, betölti a DVD-t, felpörgeti, majd röviddel utána egy kis kattanás kíséretében leáll. A kattanás a fej mozgatásából ered. Úgy látom, hogy ilyenkor még befelé koppanásig mozdul a fej majd vissza, Ezt a felpörgetés leállás ciklust kb. 9-10-szer ismétli, majd csönd. Mivel úgy tudom, hogy a felpörgetés feltétele, hogy az olvasó fej fókuszt találva felismerje a lemezt, arra gondolok, hogy a fej vagy a lézer mégiscsak működőképes. De akkor mi lehet a baj?
Még annyi, hogy van egy csavar a meghajtó mechanikában a fej magasság beállítására. Ezt már nagyon kis lépésekben végigpróbáltam, de nincs változás.
Blaupunkt Peugeot T1 autórádió kód Megoldódot
Sziasztok! Blaupunkt PEUGEOT T1 LOW autórádió kódja kellene a szomszédom akut cserélt és nem tudja a rádió kódját. Próbálkozott és már ERROR 2 ír ki a rádió. Gysz: BP8140W1571316 Ha valaki tud segíteni köszönettel vennénk. Üdv Csaba
