AUDIO-RESEARCH LS1 PREAMPLIFIER
580.9 KB
Looking for similar audio manual?
AUDIO-RESEARCH LS1 PREAMPLIFIER service manual (1st page)
Preview of AUDIO-RESEARCH LS1 PREAMPLIFIER [1st page]
AUDIO-RESEARCH LS1 PREAMPLIFIER service manual (2nd page)
Preview of AUDIO-RESEARCH LS1 PREAMPLIFIER [2nd page]
    LS-1 LS1 LS AUDIO RESEARCH
Sony STR-DE 225 Receiver, sudden interruption of Audio, after switching off everything is ok again
Hello, I got a problem with my Sony Receiver STR-DE 225.
There´s a sudden interruption of Audio in non defined intervalls - may be once ore 6 times during appr. 5hrs operation.
Interruption does not depend on Volume. Connection cables and speakers I´ve checked.
There´s a loud crack in both speakers, display shows for short time "PROTECTION".
After switching off and on again, everything operates normal until next interruption.
I removed from the inside of the receiver a lot of dust with a vacuum cleaner, but this didn´t help.
Unfortunately Sony has no documents for this device, as it is To "old" (1996), or could give me a hint,
in what cases "PROTECTION" might appear.
Is there anyone to give me a clue?  Thanks
looking for service manual: Cambridge Audio Stream Magic6 v1
Hi,
I am looking for the service manual "Cambridge Audio Stream Magic6 v1" or the schematic of the power supply.
Thanks in advance
Phil
Mekkora lehet az Presonus Audiobox USB 96 hangkártya àramfelvétele az USB portról ?-Megoldva
A  Dell Latitude E5400 notebookra ,  USB portos HD-t , és USB portos Presonus Audiobox , USB 96 hangkártyát szeretnék rádugni ! De .De , nem szeretném a notebooknak a tápját túlterhelni !
Mekkora áramfelvétele lehet a hangkártyának ?
A dobozán nem látom,az user manual , pedig nincs nálam . A keredkedő oldalán az általa megadott műszaki adatok között nem szerepel (?)
Ehhez kérem a segítségeteket ?
https://kytary.hu/presonus-audiobox-usb-96/HN099274/?gclid=Cj0KCQjwj7v0BRDOARIsAGh37iriv7iLiwgIS53BwjzXNHQq9bek2SFmp3gfJJl-QZGZNszRXtWFdScaAoBDEALw_wcB
Tivoli audio PAL - kisrádió
Sziasztok! Itt van ez a rádió javításra. Az alapvető probléma az volt, hogy időnként felhangosodott magától a készülék. Ezzel a problémával együtt jár, hogy ha csak akkumulátorról megy a rádió ez a felhangosodás tényében ki is merül, de ha a hálózati adapter (is) be van kötve, akkor begerjed a végfokozat, a tápegység stabilizálatlansága miatt kb. 100Hz-es frekvenciával. Most ott tartok, hogy beépítettem egy hálózati stabilizálást, így hálózatról sem gerjed be. De kezdek rájönni ez csak tüneti kezelés volt, nem a probléma megoldása. A probléma a végfokozat körül van. A végfok egy TDA7056B névre hallgató ic, ebbe bele van építve egy DC hangerőszabályzó, de a készülék tényleges hangerőszabályzása a hagyományos módszerrel történik, ennek ellenére az ic-be épített szabályzás is be van fűzve a rendszerbe néhány smd alkatrészen keresztül. Az biztos, hogy a felhangosodást az ebben a körben levő zavar okozza, mert rámérve műszerrel más feszültség van a szabályzásra szolgáló lábon. Bekapcsolás után bizonytalan idővel ugrás szerűen felhangosodik, úgy marad, ki- és bekapcsolás után az alacsonyabb hangerő visszajön, majd bizonytalan idő után ismét ugrás szerűen felhangosodik. Esetleg van valakinek ötlete (vagy netáán kapcsolási rajza) erre a problémára?
