BELMONT RADIO CORP. 40A AC SCH
42.4 KB
Looking for similar belmont manual?
BELMONT RADIO CORP. 40A AC SCH service manual (1st page)
Preview of BELMONT RADIO CORP. 40A AC SCH [1st page]
BELMONT RADIO CORP. 40A AC SCH service manual (2nd page)
Preview of BELMONT RADIO CORP. 40A AC SCH [2nd page]
    BELMONT RADIO CORP. AC 40A 40
ONKYO TX-DS494 low volume problem solving experience
Hello. here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494. In order to sell this amplifier I had to check if all the outputs and all the functions works properly. On the back of this amplifier you have to frontal output : A and B. I connect a pair of speaker on A output : no problem. I can adjust volume. when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize. With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated. I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays. I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly. here is my experience in repairing an amplifier
C - Giant M20 gitár erősítő némítás működése
A cimbeli erősítő végfoka előtt található 2SK30A némítást végző fet vezérléséről van-e valakinek információja. Ha kiveszem a fet-et működik az erősítő.
Esetleg egy rajz sokat segítene.
Megoldva:
A fet gate-je egy 10 uF-en keresztül fel van kötve plusz-ra. Egy 1 mohm-mal pedig a földre. Bekapcsoláskor rögtön nyit és összeköti a TDA 2030 +/- bemenetét. Ahogy a kondi feltöltődik  indul a végfok. A 10 uF volt szakadt, és nem tudott zárni a fet!
Akai szalagos magnetofon a szigethalmi piacon
Üdv,
Van egy ilyen készülék a szigethalmi piacon az egyik recycling managernél,hátha érdekel valakit.
15e Ft-ra tartja ,de hát ez piac.
elmos10029a
sziasztok--megtudna valaki mondani mit csinal egy BMW autoban,egy aramkori modulon,az elmos 10029a tipusu ic? esetleg a kivezetesek neveit? koszonom...
