BELMONT RADIO CORP. 793B SCH
74.3 KB
Looking for similar belmont manual?
BELMONT RADIO CORP. 793B SCH service manual (1st page)
Preview of BELMONT RADIO CORP. 793B SCH [1st page]
BELMONT RADIO CORP. 793B SCH service manual (2nd page)
Preview of BELMONT RADIO CORP. 793B SCH [2nd page]
    BELMONT RADIO CORP. 793B 793
I need service manual of POWERSOFT K10
Hello All
please I need technical documents for powersoft K10 audio amplifier plz
thank u
Akai 4000 tengely vastagító külmérete?
Üdv! Van kéznél valakinek egy ilyen Akai 4000-es magnója meg egy mikrométere? Megkérném az illetőt, hogy mérje meg nekem a tengelyvastagító cső külső átmérőjét...!
NAD 3140 amplifier - power transistors getting hot
This one had been sitting in a barn for years. Powered it up and the large power transistors on the heat sink would get hot
after a time....and the heat sink would also get quite hot. Speakers sounded like they had some DC on them....with a loud thump
Found the manual on Hi-Fi engine,
http://www.mediafire.com/file/b8mlsu7q3pz0bvf/hfe_nad_3140_service.pdf/file ]
and saw a video on youtube saying lots of capacitors dry out
due to their locations near resistors that get very hot, I guess sorta a poor
design. Went in and recapped almost the entire
product save for the (4) large 50V PS caps which appear to check ok.None of
the high power or driver transistors
mounted to the main heat sink were shorted..
Powered on but no audio, and noticed the fuses to Bridge D805 were melted open.
I believe they were ok before.
Replaced them and they started to light up like fiilaments, so shut down,
removed the bridge D805, then checked it, its ok.
There is about a 16 ohm short on the + / - lands where the bridge was. It
seems like something I did maybe is causing this,
like a capacitor in backwards, which I am doing alot of lately for some
reason.
Turns out, yep I put C805 (470/ 63) In backwards ! Capacitor still checks
ok, so will re-use it.
Short is still there though Im guessing R803 is adding in 5.6 ohms or so,
that means theres a 10 ohm short someplace. Q801, 802 arent reading short,
and looks like this becomes a +43V ps feed.
Any ideas out there on what to check next? I am guessing this cap in
backwards caused the voltage applied to a component to be
reverse and its shorted. Or would this be normal with a reversed cap installed,
and putting it in right would be how to fix it?
Steve Hearns
Technotronic Dimensions [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
Videoton EA 6383--Egyenlőre csak gyenge erőlködő (már rendesen erősít).
Szép estét az Uraknak! Megint zaklatnám a társaságot a következőkkel: Kaptam egy ilyen, a címben szereplő szerkezetet, ami természetesen rossz, de külsőleg igen szép állapotban van. Ha mód volna rá, szeretném megjavítani, mert kíváncsi vagyok a hangjára, meg hát, ha már itt van ez a számomra szépség, hadd szóljon újra rendesen. Amit eddig tudok: Az egyik oldala szól, de csak halkan. A másik oldal néma. Csináltam egy kábelt RCA ról DIN re, remélem jó. A 3-as, 5-ös lábról megy egy-egy RCA-ra + a 2-es láb a föld. Ha a középső -szabályzó- panelról lehúzom a csatlakozót hangosabban szól. Olvastam róla hogy ebben van valami némító dolog, ami nem működik, sem így, sem úgy. A végtranyókon (BD809-810) meg van a 34V, és a meghajtóknál (BD139-140) is, ezt kimértem. A kivezérlésjelző mutat -teljes hangerőn- mindkét oldalon lehúzott csatival olyan 3W-ot, de feldugott csatival csak 0,5W-ot. Észrevettem azt is, hogy ha a választó kapcsolók közül egyik sincs bekapcsolva akkor is hangosabb. A két 4700uF pufferkondi közül valószínűleg az egyik elfáradt, mert fehér folyásszáradék van a kivezetés mellett. Azt szeretném kérdezni, merre induljak el vele? Nem akarom széttúrni, kár volna érte. Ahogy néztem, még teljesen szűz. Tudnotok kell, hogy csak kezdő amatőr vagyok a témában, tehát, ha kérhetem laikus nyelven adjatok tanácsokat. Várom a hozzáértők szíves válaszát, hozzászólását. Köszönettel: Egérfogó
