Preview of BIAMP SPM522D MIX SCH PCB [1st page] Click on the link for free download!
Preview of BIAMP SPM522D MIX SCH PCB [2nd page] Click on the link for free download!
Also known:
BIAMP SPM-522D MIX PCB SPM522D SPM 522
If you have any question about repairing write your question to the Message board. For this no need registration.
If the site has helped you and you also want to help others, please Upload a manual, circuit diagram or eeprom that is not yet available on the site. Have a nice Day!
Warning! If you are not familiar with electronics, do not attempt to repair! You could suffer a fatal electrical shock! Instead, contact your nearest service center!
Note! To open downloaded files you need acrobat reader or similar pdf reader program. In addition,
some files are archived, so you need WinZip or WinRar to open that files. Also some files are djvu so you need djvu viewer to open them.
A barátom cd játékosa került hozzám nemrég, a sztori úgy indult hogy egyszer csak elhallgatott és se kép se hang, ennek 5 éve most elhozta hogy kukkolja már bele mi lehet a nyűgje, első bizti csere mivel ki volt égve, aztán ráköt a hifire és csak ilyen sercegéses zúgás tör elő belőle, cd bele olvas mindent, de a zene mellé párosul ez a búgó zúgó hang mintha test hiánya lenne de ezt átnéztem és minden rendben, ötleteket szivesen fogadok.
Egy kis videó arról hogy mi a hiba:
Hello.
here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494.
In order to sell this amplifier I had to check if all the outputs and all the functions works properly.
On the back of this amplifier you have to frontal output : A and B.
I connect a pair of speaker on A output : no problem. I can adjust volume.
when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize.
With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated.
I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays.
I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly.
here is my experience in repairing an amplifier
Szervusztok!
Tud valaki ajaánlani (lehetőleg Dél-Pest környékén) megbízható -és persze, viszonylag olcsó- trafótekercselőt?
Egy WSH110 trafóról volna szó, amit leégettek, a primerje biztosan zárlatos.
Köszönettel:
Tiszteletem!
A fent nevezett erősítőben zárlatos lett pár db dióda ,ami oa90 germánium.(d308,d302)
Kérdésem az lenne hogy mivel válthatnám ki? Pl 4148?
Üdv:Imre
If you want to join us and get repairing help please sign in or sign up by completing a simple electrical test or write your question to the Message board without registration. You can write in English language into the forum (not only in Hungarian)!
