BOLLETINO TECNICO GELOSO 85 1962
13.3 MB
Looking for similar bolletino manual?
BOLLETINO TECNICO GELOSO 85 1962 service manual (1st page)
Preview of BOLLETINO TECNICO GELOSO 85 1962 [1st page]
BOLLETINO TECNICO GELOSO 85 1962 service manual (2nd page)
Preview of BOLLETINO TECNICO GELOSO 85 1962 [2nd page]
Sansui A-510 erősítő nem nagyon reagál a hangszínre.
Lenne ez a erősítő. A mélyre nem nagyon reagál, mindkét csatornán, a magasra úgy ahogy, igen.
Próbálom mozgatni a poti tengelyt, de semmi....
A balance, mély, magas potik egy fém hidra vannak erősítve, és úgy beforrasztva.
Mielőtt kibontom a hidat, lehet valami más bibi a hangszín körül?
Kösz
May be useful - Harman Kardon information
For your information to repair Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown) can be changed without any other servicing Harman Kardon Receivers; Series AVR 2000,3000... "Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time. "Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V. "Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there. "volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V! "everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function. Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts. So i hope i can help you... cheers SG.
Panasonic SA-AK410 , CD Lemeztálca mozgatási hiba.
Üdv Tisztelt Mesterek !
Panasonic SA-AK410 Tálca mozgatását nem tudom beállítani.
Tudna valaki segíteni benne? Ismeri valaki?
Tanyán nagyon jó rajz és leírás van róla.
Ez egy 5 lemezes , nem forgó tálcás masina.
Több lépcsőben mozog és tölt a CD mechanika és tálca. Maga a tálca is külön tud mozogni , a tárazás alkalmával.
A tálca vagy nem megy végig, vagy  ha végig megy és kitolja a gép újra töltéshez , akkor túl tolja a fogaslécet és már nem tudja visszahúzni,
Nem mindegy hogy a tárazó és a töltő mechanika, mikor áll lent ,vagy fent.
Ha valaki ismeri ,kérem segítsen.
Előre , köszönöm.
Öreg T.
Sony STR-AV320 protect mod Megoldva.
Sziasztok.  Lett egy, a cimben szereplo tipusu erositom. Protect modban volt, a STK4182 vegfok egyik kimenetere kiult a +tapfesz. Van egy hasonlo, STR-AV210 tipusu is, ami mukodik, a radio reszet kiveve, de elegge utott-kopott. Ezert ugy hataroztam, hogy a vegfokjat, STK4152, teszem at az AV320-ba. Bar a 320-as szervizkonyve +-41.6V tapfeszt ir, a valosagban csak +-34V, igy nem kene gondot okoznia a STK4152-nek. Bekapcs utan szepen meghuz a hangszorovedo rele is, nagyon alacsony hangeron megszolalt az egyik oldal, de ha fennebb emeltem a hangerot, a rele oldott. A kimeneteken nem volt egyenfesz. Masnap ujbol elovettem oket, de most mar rogton protect modba lep. Most sincs egyenfesz a kimeneteken. Megvizsgaltam a vedo aramkort, az elektrolit kondikat csereltem, de nem valtozott semmi. A szervizkonyv szerinti feszultsegek merhetoek (kiveve a tapfeszt) mindenhol a vedoaramkorben. Mivel nem igazan vagyok hive a processzoros vedelemnek, nem is igazan ertem hogyan is mukodik ez. St-by allapotban a proci "protector" laban 4.8V van, ez a bekapcsolast koveto 2-3 mp utan leesik 0.68V-ra, ami megtalalhato az R630 - D603 kozos pontjan is. Nehany mp mulva ujbol felmegy 4.8V-ra es kiirja a protect modot. Az en tudomanyom itt megallt. Szivesen veszek minden otletet a problema megszuntetesere. Koszonom.
