BRAUN T41 FERRIT-ANTENNA TRANSISTOR RECEIVER SCH
53.4 KB
Looking for similar braun manual?
BRAUN T41 FERRIT-ANTENNA TRANSISTOR RECEIVER SCH service manual (1st page)
Preview of BRAUN T41 FERRIT-ANTENNA TRANSISTOR RECEIVER SCH [1st page]
    BRAUN T-41 TRANSISTOR RECEIVER T41 41 FERRIT ANTENNA
NAD 3140 amplifier - power transistors getting hot
This one had been sitting in a barn for years. Powered it up and the large power transistors on the heat sink would get hot
after a time....and the heat sink would also get quite hot. Speakers sounded like they had some DC on them....with a loud thump
Found the manual on Hi-Fi engine,
http://www.mediafire.com/file/b8mlsu7q3pz0bvf/hfe_nad_3140_service.pdf/file ]
and saw a video on youtube saying lots of capacitors dry out
due to their locations near resistors that get very hot, I guess sorta a poor
design. Went in and recapped almost the entire
product save for the (4) large 50V PS caps which appear to check ok.None of
the high power or driver transistors
mounted to the main heat sink were shorted..
Powered on but no audio, and noticed the fuses to Bridge D805 were melted open.
I believe they were ok before.
Replaced them and they started to light up like fiilaments, so shut down,
removed the bridge D805, then checked it, its ok.
There is about a 16 ohm short on the + / - lands where the bridge was. It
seems like something I did maybe is causing this,
like a capacitor in backwards, which I am doing alot of lately for some
reason.
Turns out, yep I put C805 (470/ 63) In backwards ! Capacitor still checks
ok, so will re-use it.
Short is still there though Im guessing R803 is adding in 5.6 ohms or so,
that means theres a 10 ohm short someplace. Q801, 802 arent reading short,
and looks like this becomes a +43V ps feed.
Any ideas out there on what to check next? I am guessing this cap in
backwards caused the voltage applied to a component to be
reverse and its shorted. Or would this be normal with a reversed cap installed,
and putting it in right would be how to fix it?
Steve Hearns
Technotronic Dimensions [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
Thomson TM9670 áramköri elemek értékei (SM)
Sziasztok! Kicsit meggyűlt a bajom a Thomson TM9670-nel, és ezért szeretném a segítségeteket kérni. Ha megvolna a teljes Service Manualja úgy kérlek benneteket, hogy küldjétek el nekem az alábbi email címre. fokaberci88@freemail.hu Amennyiben ez nem lehetséges akkor esetleg megtudnátok mondani a következő értékeket? R601 R796 L706 C727 C726 C718 A segítségeteket előre is köszönöm. Üdv: Fókaberci
Panasonic SA-HE90 Overload hibaüzenet bekapcsoláskor
Van egy Panasonic SA-HE90 házimozierősítőm, ami bekapcsoláskor "Overload" hibaüzenettel indul és kéri a kikapcsolását. A relék nem kattannak.
A gép közel 20 éves, eddig gyönyörűen működött, ugyanezekkel a hangfalakkal, nem történt változás ezen a téren.
Az eredeti hibája az volt, hogy a Front A bal csatorna elkezdett vacakolni, azaz halkan nem szólt, csak ha már jócskán feltekertem a hangerőt és akkor is csak hangos részletekkor, a halkak mint egy zajzár esetén elvesztek. Gondoltam valami kiszáradt vacak forrasztás lehet az oka, így szétszedtem és azokon a helyeken, ahol csúnyább volt vagy láthatóan nagyon spóroltak az ónnal, felfrissítettem a forrasztásokat. Nem ma kezdtem a forrasztással foglalkozást, szóval nem elgányoltam, hanem szépen kiszippantottam kiforrasztópisztollyal és friss ónnal pótoltam a forrasztásokat.
Összerakás után csak az Overload jelenik meg 2-3 mp után és nem kattannak a relék.
Bármilyen ötletért akár az overload-ra, akár az eredeti problémára hálás lennék.
Ha valaki foglalkozik ezzel a szériával Esztergom környékén, szívesen átadnám a problémát. Nem értek az erősítőkhöz ilyen mélységekben, de nagyon szeretem ezt a darabot :)
Köszönettel,
Andreaux
Technics RS-B665 magnó deck hiba
Hello!
A címben szereplő készülék hibátlanul lett eltéve jó pár (~15-20) év pihenőre egy fűtetlen garázsba.
Olyan hibát produkált nemrég, hogy a PLAY-t megnyomva REC módban indult el. Leszedtem az előlapi panelját a főpanelról és a csatlakozó lapkákat megtisztogattam amennyire tudtam, ill. egy vezérléshez/mechanikához menő 3 eres kábel egyik ere sérült/törött volt közvetlenül a csatlakozónál, így azt rendbe hoztam. A PLAY/REC probléma elmúlt, de jött helyette más.
Tovább akarok tekerni (FF) és elindul REV irányba. Ezt azzal tudom kiküszöbölni, hogy nyomva tartom a FF gombot még 2-3 mp-ig és akkor valóban arra teker, amerre én szeretném. (FF-REV-FF szédelgése után).
Buherálva nem volt korábban, pusztán kazetta megvilágítás került bele teljesen különálló tápról és egy A-B oldal jelző optocsatolós elektronika, de ez is a külön tápon... és ezek után még hibátlanul működött éveken át.
Mivel a PLAY/REC problémát a csatlakozó és/vagy kábelhiba is okozhatta, és annó nem produkált ilyen hibát, már nem tudom merre felé keressem a megoldást. Végül is nem egy akkora probléma, csak bosszantó.
Ha valaki ismeri a készüléket és tapasztalt már hasonlót... majd megtalálta a megoldást is, örülnék, ha megosztaná velem.
