BURNDEPT 266 VIDOR 277 RECEIVER 1945 SM
389.8 KB
Looking for similar burndept manual?
BURNDEPT 266 VIDOR 277 RECEIVER 1945 SM service manual (1st page)
Preview of BURNDEPT 266 VIDOR 277 RECEIVER 1945 SM [1st page]
BURNDEPT 266 VIDOR 277 RECEIVER 1945 SM service manual (2nd page)
Preview of BURNDEPT 266 VIDOR 277 RECEIVER 1945 SM [2nd page]
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
QFP-144 tokozású ic cserélésére keresek szakit Megoldva
Megérkezett a várva várt ic, ehhez keresnék valakit aki kicserélné.
Természetesen minden költségtérítéssel, nem ingyen kérem.
Rotel rsx-1065 erősítő procija, ahhoz hogy továbblépjek a hibakeresésben, ahhoz a procit mindenképp cserélni kell.
Az alaplapot és az új ic-t külön küldeném el, nem az egész erősítőt.Hangsújozom, nem volt kísérlet a cserére, teljesen érintettlen, nincs "barmolva", ez nekem kicsit még "magas".
Természetesen garanciát nem kérek a működésre, csak legyen "helyesen" és szépen cserélve, mint mondtam ez csak még egy esély az erősítőnek.
Előre is köszönöm.
Seat Sound System (Grundig) fejegység magától bekapcsol
Sziasztok! A fenti fejegység véletlenszerűen, de percenként bekapcsol. Bekapcsolt állapotban a TAPE-RDS felirat villog 10-15Hz-el (kb.) és ilyenkor elhallgat. Nosza valamelyik mechanika végálláskapcsoló kh-s. De nem egyik sem kh-s. Próbáltam azt, hogy az alaphelyzetbe zárót összeforrasztottam a bontóról pedig leforrasztottam az egyik vezetéket. Helyzet változatlan. Szkóppal méricskélve az egyik kapcsoló (alaphelyzetben bontott állapotban van) lábán alaktalan, hullámzó véletlenszerűen változó jel van. Amikor ez a jel eléri a 2V-ot akkor kapcsol magnóra (TAPE). Néha begerjed és szabályos négyszögjel van a lábán, olyankor villog a kijelzőn a felirat (jogosan). Kérdés, hogy mi ott az a zavar, mitől lesz négyszögjel és honnan jön? Tudom kettőt és könnyebbet, de egész délután ezzel küzdök, már tikkel a szemem. Rajzot nem találtam, de jól jönne. Csatolom az előlapot, hátha ismerős valakinek. Üdv.
Technics SA-EX310
Sziasztok ! Keresek a fent említett erősítőbe procit ! M38B53M4053F . Ezekben lakozik az a híres RSN végfok is, amit aranyárban mérnek. Ez a végfok jó , viszont csináltam benne egy műhibát , és a proci drót lett. Ha valakinek van bontásban, és hajlandó tőle megválni , akkor azt megvenném . Előre is köszönöm !
