CALIFONE 3410AV 3430AV SM
647.3 KB
Looking for similar califone manual?
CALIFONE 3410AV 3430AV SM service manual (1st page)
Preview of CALIFONE 3410AV 3430AV SM [1st page]
CALIFONE 3410AV 3430AV SM service manual (2nd page)
Preview of CALIFONE 3410AV 3430AV SM [2nd page]
    CALIFONE 3410AV 3430AV 3410 AV 3430
Marantz SR6007 no fonction
Hello
I'm looking for your help in troubleshooting a Marantz SR6007 amp that shows no signs of life. The 5.2 V standby power supply (STBY) is present, the 3.3M is also present but I have no feedback from the processor which should control the start functions. You have an idea ?
Thanks
Keresek STK 463
keresek stk 463 ic t.de már kifutott termék .
AKAI Gx-747 nem indul
Kedves Fórumtagok,
A probléma: AKAI GX-747 orsós magnó nem indul.
A kijelzők világítanak, a tension karok működnek, a görgőt felhúzza a mágnes, de az orsók nem indulnak el egyik irányba sem.
A gyors tekercselés működik, mindkét irányban.
'Kicsomagoltam' amennyire tudtam, és a tudásomból tellett...
Az olvadó biztosítékok rendben, de a capstan motor / tengely nem forog.
Vajon elektronika, vagy motor hiba, vagy egyéb?
Videókat mellékeltem, remélem megnyitható.
Előre is köszönöm a segítséget, és esetleg egy AKAI 'professzor' elérhetőségét :)
Albert Tamás
Onkyo DX-7333 CD player sometimes doesn't recognize CDs
I have a Onkyo DX-7333 CD player, which sometimes doesn't recognize CDs. I don't think it's a laser pickup (KSS-213C) problem, because when it recognizes the CD, it plays it without a problem, even very scratched ones. The next thing is, it should play CD-RWs, but it doesn't even recognize them. I think it needs adjustment There are two pots on the main PCB - Focus Gain R123 and Focus Offset R112. Also there are two test points: TP1 4 pins, first pair labelled Tracking Gain, second pair Focus Gain TP2 2 pins labelled RF Out and VC But in the service manual is no description, what should be measured on the test points and how to set Focus Gain and Focus Offset. In the attachment is a cut out from the schematic, where the test points and adjustment pots are. Please if someone knows, how to?
