Hello everybody in Hungary,
I am looking for schematic diagram of portable player THOMSON TM9670.
When I connect an USB drive into the machine, the normal supply voltage 5.5V drops to approx. 2.0V in dependency of each usb drive. The player reports that no usb is connected.
I found out that power supply circuit comes from transistor D882L – from pin No.3 which is base pin. This doesn’t make any sense to me. I would expect it should be connected to collector or emitor pin. Therefore I need schematic diagram or service manual for this player.
Thank you in advance for any help.
Regards,
smith666
2018, May 30 - 13:42
#1
Dear smith666,
If You need schematics, try the Wanted box in right side: https://elektrotanya.com/rec_wanted
Regards,
Jaca
I did it,
Thank you Jaca![yes yes](//cdn.ckeditor.com/4.5.4/full-all/plugins/smiley/images/thumbs_up.png)
