I have this TV equipped with the source BN44-00134A.Tv does not start, it is heard how the relay is continuously coupling and disconnecting. The stable voltage drop is STB = 6.5V, P-ON / OFF varies between 0.2-2.5V in normal operation = 2.6V) PFC between 360-385V (when going is 382V). All electrolytes, secondary-primary, have been changed, except the 220uF / 450V which is ok. In this state, if measure the voltage on the pins 1-2 to optocoupler PCS802, the relay stay connect and tv work normally . I have replaced the PCS802,801, the ICS 802 (KIA431), the QP803, the QS801, the QS802 checked. If I stop it(unplugged) and I restart the tv in a few minutes, it works normally, if I leave it a little longer, the defect returns. Any suggestion is welcome, I do not think it would be the problem with the mainboard. Thank you!
I attach the power supply+ inverter schematic model BN44-00134A
2019, May 21 - 12:14
#1
Hi,
this is common problem on this and similar. You need eeprom dump, it should solve this problem. The problem i caused by bad caps on power board.
best regards
Thank you very much, you were right, alterated eeprom 24C32. Fixed the problem by replacing it with an empty memory (FF).The best regards”
Hi,
I'll try this too,the best regards
Hello!
I would blow your parts with KALTE-75 sray in your place!
Varga Jano
I'm sorry but I did not understand what you wanted to tell me ... did you refer to using the cooling spray to locate the fault? Thank you!
Yes.Yes.
OK, thanks!
