APC Back-UPS ES 700VA, beeping and outputs shut down
What could be a problem when that ES 700 VA UPS started to cut off it's output voltages from upper and lower schuko-connector banks, and start to beep continuously at same time? While it's boot sequences end it starts to make some low level noise as something needs additional amount of current, or similar. Then some relay latches, beeping starts and outputs shuts down. Green pwr-led shuts down too and Maaster-slave -system won't work neither (that led do not dimm at all). That happens similarly next starting time, it won't stop that behaviour.
(Quick test showed that: when feeding itself from it's master-connector it starts and stays on pretending that all is ok, but it wont last for example small soldering station current, etc..).
It has been serving us 2-3 years feeding some networking and computers, from cooler place than normal living room.
It's battery is not guilty, I have tested with two batteries (good 12 Ah and brand new 9 Ah, both fully charged before installing into UPS rear slot) instead of that original one, but nothing changes.
I tried to use it now at my HF radioamateur station (with a lan switch, several computers and other ham shack equipments, etc) so additional RF fields might has be near (especially when using FT8-mode) it, but max total ampere rating drawn from it has not exceeded 10 A (230 VAC).
Any ideas where to look first? Before throwing it to CER and replacing that with some other one..
Regards, Kari
Paul Cole
Paul Cole picture
Replace capacitors C14 and C30 (22µF). May need to replace C2, C3 and C51 capacitors (all 22 µF) too.
I replaced all above and mine is now working perfectly.
It is a quick and easy fix.
Good luck. :)
OH5XB
OH5XB picture
Thanks everyone,
 I'll try those.
HNY,
Kari
Kari
Kari picture
Haliho!
Csak jeleznem: semmi közöm sincs hozza...
Kari_a réges-régen reggelt
CRC
CRC picture
De ugye a spaceboy-hoz sem? ;)
Kari
Kari picture
Gözöm sincs rola, hogy kiröl-mröl beszelsz...
CRC
CRC picture
Az az űrhajófejlesztő egy egy bejegyzéses (akkor, csak a bejegyzés törölve lett) tuti kettős reg. Angolul írt de 100% hogy a szűkebben vett fórumozók egyike. Nem állítom hogy Te lennél de a jellegzetes stílusod, egyébként nem csak a tiéd, angolul írva fedhető el legkönnyebben.
Kari
Kari picture
Elöbb azert erösebben majdnem allitottad, hogy en lennek, DE nyilvan eszrevetted, hogy utobbi idöben erösen csökkent az itteni aktivitasom, idöhiany-egyebek miatt sokmindent nem olvasok-igy erröl sem lehet(ett) tudomasom = masvalakit gyanusits_ ha minden aron az a celod!!
frankozéro
frankozéro picture
Már megoldva, kondikat kell cserélni!
De te levédetted a neved, hogy így háborogsz?
..ja regelt az nem"reggelt", de biztos nálad reggel volt!
Ideje lenne abbahagyni a trollkodást, mert kitiltás lesz a vége. Nem szólok többet!
Ezt nem értem. Én lennék a troll, az előttem szólók akkor mik?
Szóltam hogy alakul a javítás és a helyesírást javítottam.  A név hisztit azt megint csak nem értem.
Elnézést ha hibáztam!
Sok lesz a visszaszólásból. Nem levelezni akarok, csupán közöltem a miheztartás végett az elvárásokat.
CRC
CRC picture
A törölt bejegyzése után mely hozzám szólt és nem fogom idézni, semmi aktivitást nem mutatott tavaly dec.29. 11:37 óta.
Minden esetre nagyon fura az egész. Ha nem jelentkezik be valaki, akkor is látom ha itt van. Szoktam figyelni a jelenlevőket ugyan is.
