Panasonic tcl32x30a flashing once
led modelo tcl32x30a..al encender titila una vez,podria alguien decirme como puedo reparar la falla
Panasonic led tv model tcl32x30a. Flashing once. Could someone tell me how I can repair the fault?
Jon Snell
Jon Snell picture
The fault is within the A or main board.
There are a number of causes, from a BGA re-flow required to power failure on the board.
Most just replace the A board.
Mykola
Mykola picture
Hi Jon, when you have received flash error #1 - it means that back-light is fault.
You should check back lighting circuit.
