2 posts / 0 new
Ali_dz
Ali_dz picture
Hello everybody,
Ali_dz
Ali_dz picture
Hello,
With  high difficulty, I've finally fixed the problems as fellows:
1-  The harness's cut wire is  welded with a classic tin and thin soldering iron.
2- The flex cable is also fixed after bypassing the worn out connexion and wrip others.
Thanks for you all.
